Stator coil upgrade
Stator coil upgrade
Hi - Does anyone here have the recipe to upgrade the wiring on the UK stator? I don't need the sort of power a Ricky stator puts out and I can't get them in my country. What I need is what gauge wire and how many windings to improve the stock stator
Re: Stator coil upgrade
Does this link help....
https://thumpertalk.com/forums/topic/330632-diy-stator-rewind-on-xrr/
Mauser wrote:Does this link help....
I will give it a try - Thanks
I have a mate who winds guitar coils, I will try get him to help. Just need to pick up 0.5kg 1.02mm wire and some epoxy
0.5KG sounds a lot of wire lol.....you hoping to generate 1.21 gigawatts ?
In order to travel through time, the vehicle integrated with the flux capacitor needed to be traveling at 88 mph (140.8 km/h), and required 1.21 gigawatts of power (1,210,000,000 watts), originally supplied by a plutonium-powered nuclear reactor.
Mauser wrote:0.5KG sounds a lot of wire lol.....you hoping to generate 1.21 gigawatts ?In order to travel through time, the vehicle integrated with the flux capacitor needed to be traveling at 88 mph (140.8 km/h), and required 1.21 gigawatts of power (1,210,000,000 watts), originally supplied by a plutonium-powered nuclear reactor.
Probably the least they will sell. The instructions say 1lb of wire
I installed this:
https://www.electrexworld.co.uk/cgi-bin/sh000001.pl?WD=xr650&PN=G443-RR17%2ehtml#SID=200
Works great! Note that you will need to install either a battery or a capacitor (I went with a capacitor) to 'absorb' the extra power is produces.
SkidMark wrote:I installed this:
Is it plug and play? Do all the plugs fit straight in the harness?
Hmmm good question - it was a while ago. From what I remember it was easy enough to do although you will probably have do to some wiring depending on if you go with a battery or capacitor and where you locate them.
The reg/rect is larger than the stock one although I still got it under the seat. If I remember correctly I had to cut out a little plastic barrier that helped keep the stock one in place. I managed to get the capacitor under the seat but attached to the outside of the frame rail with zip ties - essentially it is located under the seat under where my right thigh sits if that makes sense. If your not sure I can maybe take a picture tonight or tomorrow if you want.
Cheers,
Cheers,
They say it is 250W
If 34 coils of 1mm only gives 100W then how does Electrexworld get 250W? I would like to get my stator rewound to a decent spec and have someone locally that can wind it
» Stator upgrade
» Stator Upgrade
» New owner of a 2000 XR650R Uncorked and Baja Kit
» brake upgrade
» Baja Designs Squadron Pro headlight upgrade
» Stator Upgrade
» brake upgrade
