Swapping springs front and rear.....
I've been checking the literature and postings everywhere and have come to the conclusion to swap my stock springs for .47kg front and 11.0kg rear. I'm about 230lbs.
Is there any special consideration for fork oil I should be aware of? Should I just swap the springs up front and leave the oil alone?
I'm not doing any additional valving etc. at this time maybe later.
thanks,
kjazz
thanks,
kjazz
Re: Swapping springs front and rear.....
Those are the springs that came on my bike.
I just got 12 on the back and .49 in the front, and I am 300lbs and ride like a pussy.
The current springs actually feel fine, I never have bottomed the bike, but keep in mind I have never jumped the pig, but have gone over some prtty big stutter bumps and whoops.
I think those springs might be on the stiff side for your skinny ass, but hey what the **** do I know?
I weight 240 + all my gear & run the Acerbis Sahara tank. NOST re-did my suspension with a .49 front & a 11.5 rear. It came out so well I have never turned an adjustment screw since they did it. I have people on lighter bikes that have riden behind me ask about the suspension commenting on how well the bike tracks through the gnarly stuff. They only charged~300 more to rebuild mine over what the springs would've cost to buy.
Two more questions regarding the fork spring swap.....
1) I understand that I need to measure distance from top of fork to oil level for setting the correct volume of oil, but.... how much will it likely take for two forks? So I dont have to go back and forth to the parts store more than once?
2) I understand the stock oil is 10 wt. I'm told with stiffer springs I might want to use a 7.5 wt. oil for a bit more supple reponse. Any comments on that idea?
» Do YOU need different springs??
» Stiffer springs
» Can someone tell me if I need new suspension springs???
» New springs from Racetech
» Bornyack - Cutting springs?
» Stiffer springs
