XR680 build/rebuild
Page 1 of 2
Page 1 of 2 • 1, 2
Re: XR680 build/rebuild
I've seen the stuff you posted over on Supermotojunkie.com very nice.
Got a link?
Got a link to Supermotojunkie?
Clipity wrote:I've seen the stuff you posted over on Supermotojunkie.com very nice.
First off, let me just say that is one SICK bike... I'd love to have that...
Secondly, a couple questions;
Did you fab up that rear fender yourself; the stocker w/ like a CR 250 fender?
Did you custom build that header? I've always liked the header wrapped around the other side of the engine design; seemed to make sense w/ the way the exhaust port is angled on that side.
Lastly, is that carb the FCR? It looks like it, but I'm not sure...
Thx
You can find most here:
http://www.supermotojunkie.com/showthread.php?t=83358
The rear fender and panels are from a crf450 '05 : cut and modded to fit,underneath sits the OEM fender (cut).
The carb is a first generation FCR carb (road racing),oval bored to 43mm by the Dutch VHM firm.
I rode the bike today (run in) and the power with the 680 is insane,lifting the front when he comes in the meat of the power (3000 a 4000 rpm) even with 15 x 40 sprockets.
It's a Monnier tank with modded '03 CRF shrouds. It's a Swiss firm: http://www.spracing.ch/
In Italia they make alu tanks with CRF '05 shrouds : http://www.blitalia.com/catalogo/dettagli.php?cID=2&pID=5
Here are some more pics....
Specs and mods:
-Base: Honda XR650R model 2000
-Engine: - Falicon rod Xr's only HD bearing
- 680cc cylinder: nicasil plated by Luyten (Wiseco.be)
- Modified 102.4mm Wiseco piston
- 11.5/1 copression
- Hotcams stage 2
- Port and polished head,matched intake
- Knibblewhite valves: intake 1mm oversize,exhaust standard size
- Keihin FCR41 bored to 43mm by VHM.nl
- Advantage performance Flex Jet fuel screw
- Light flywheel
- Hi rev CDI
- Modded Twin Air filter with home designed frame
- Airbox mod
- Red CV4 silicone hoses
- Patevo Exhaust (France)
- Case saver (home design)
- Scott Summers clutch mod with a mix of OEM and HRC springs
-Frame: - OEM frame modded to accept CRF steering damper
- Black coated
- CRF 450 '03 Showa Twin chamber fork with SMJ specs valving
- Moddified Applied CRF clamps
- Universal OS handle bar
- Breaking Wave disks front/rear
- Brembo Billet 4 piston (Titanium) caliper Nissin master (old MotoGP stuff)
- Ohlin shock (SM revalved & resprung)
- Modded red Talon hubs laced with black Excel rims (3.25"/5")
- Customs crash bobins
- 15 x 40 sprockets with RK xvw ring chain
- Modded SDG seat
-Bodywork: - CRF '03 Acerbis shrouds on 7l Monnier tank
- CRF '05 Acerbis modded sidepanels rearfender
- Acerbis SM handguards
- Racetech plastic from Hells.de:
- V face headlight
- SM frontfender
- Extreme led rearlight
- H-one unbreakble clutch lever from Hells.de
- Trailtech Vapor dashboard
- Light Speed carbon fork guards
- Modded Orco Concept (France) carbon engine guard
That's all folks !
Specs and mods:
- 11.5/1 copression
- Hotcams stage 2
- Light flywheel
- Hi rev CDI
- Airbox mod
- Black coated
- Modded SDG seat
- V face headlight
- SM frontfender
That's all folks !
PLease compare the performance between the 650 and 680 kit.
What compression are you running?
Thats an inspiration to me. I was thinking to do something like that with a XR 650R and now I found this work. I'm curious, you have any video with your XR?
hi mate i go 1 of 2 engines built for worlid supermoto its 780cc cant wait to get it complete
The pictures are dead, someone have there on his computer please ?
I would to see this XR
I've the same question posted by Aurora.
What about your feelings with 680 cc ?
Maybe an other guy had lived this experience ?
Hello ,
you can see them on my FB page here:
https://www.facebook.com/media/set/?set=a.307714032603214.70070.307704402604177&type=3
print screen windows 7
There are a lot of other project bikes on those pages.. this is on of my latest 650R projects
image hosting without registration
Thanks for your answer...
She is very nice... My new model ahaha
You are too on suoermotojunkie no ? I had see a near motorbike
I would see this page later, Thank you very much
All of Xr were yours ?
The 680 is mine, others are project bikes for clients or to sell in my shop.
You make a great job ... the last bike (10 november) is nice, a lot of work
I would to think about put my bike into your hands; you accept french XR ?
Between 650 and 680, you had a lot of difference ?
I have never read a report about this preparation and I would to remake my engine ... so it's could be interessant to know.
Bring those French XR's on ! Je parle un petit peu le français.
680 is alot of torque , combined with the right mods (stage 2 cam,big valves,big carb and special CDI) it's sometimes scary...but tooo much fun.
xrmanu wrote:680 is alot of torque
Je ne parlez pas Francais, je m'excusez - however, don't you think it's atrocious voor een Belg om dit niet te kunnen?
680/650 = 1.04 >> 4% more torque for a 680cc when compared to a std bored one!
You also say "a lot" more, quite like plenty dudes do on the net..... but it's only a measly gain of 4% ?
I'll never do it, boring out the perfect nikasil bore to gain what, next to nothing? Suuure, cam, valves, carb etc, but if you do that to a 'std' angine then you basically have the same - less bragging rights of a 'big bore' engine of course.
Quite different if you hop-up a 250 to 300 or 320 or thereabouts, that IS a real difference!
My 2c's, feel free to splash out dear dollar on a 680 kit
Page 1 of 2 • 1, 2
» This little piggy is not going to market
» New guy in New Zealand
» Where to buy carb rebuild kit - UK ?
» xrr 2016 rebuild
» Fork rebuild/overhaul
» xrr 2016 rebuild
Page 1 of 2
