SEE TO MUCH POWER
SEE TO MUCH POWER
HOW ABOUT 102.98 HP AND 66.34fpt,,,703cc,,3mill cyl lift ,,,CUSTOM RACING ROD,,, BIG BORE,,, RACING HEAD ,,,RACING PIPE with NITROUS 6psi fuel pump(top pic) 3 pound nitrous bottle in the air box (bottom pic)
How about ...
Setting that bong down for awhile just go riding?
lbrs467 wrote:HOW ABOUT 106 HP AND 77fpt,,,703cc,,3mill cyl lift ,,,CUSTOM RACING ROD,,, BIG BORE,,, RACING HEAD ,,,RACING PIPE with NITROUS
ahh, now I see it
You should hang with this guy:
https://www.youtube.com/watch?v=tLyyac-mXNI&feature=related
Re: SEE TO MUCH POWER
https://www.youtube.com/watch?v=tLyyac-mXNI&feature=related[/quote[/url]]Bump wrote:You should hang with this guy:
[url=https://www.youtube.com/watch?v=tLyyac-mXNI&feature=related
That guy did some engineering and has some skills. some of the vids he has made me wonder how he even got on his 650 R after he finished it. His bike is bad ass.
TO MUCH POWER
IT'S EASY TO MAKE THE POWER ,,,TURBO ,,,NITROUS,,,CAMS ,,, BIG BORE ,,,WHAT EVER ,,,BUT YOU WILL SMOKE THE CLUTCH,,,SHOT BLAST OR SAND BLAST THE METAL PLATES,,, EXTRA PLATES ,,,KEVLAR FRICTION PLATES,,,HEAVY SPRINGS,,, YOU JUST CANT GET THE POWER DOWN TO THE GROUND,,,YOU END UP BREAK.N THE SPRING PODS ,,,,,,BUT AT ABOUT 100 HP THINGS HOLD UP VERY WELL,,,AND YES YOU WILL BE IN THE HIGH HIGH 10'S OR LOW LOW 11'S WITH A BUCK 115 RIDER ,,,BEEN THERE DONE THAT,,, BUT IT'S VERY HARD TO KEEP IT ON THE GROUND
» WAY MORE POWER, WTH.
» 12 V Power
» How much power is left?
» XR650R engine power output
» 12 V Power
