Want a more comfortable seat? Cheap too?
Post  Bump on Sun Jul 19, 2009 11:59 pm
Cement would probably be more butt friendly!
In any case, here's a neat idea I found over at TT. Thre are some other ways to do this. Smaller holes and also filling the holes with very soft foam.
http://www.thumpertalk.com/forum/showthread.php?t=489610
How to improve stock seat foam comfort
Published by Roadracer Al
03-31-2007
If
your stock seat foam is way too hard (the DRZ, for example) you can
modify the foam to improve it's comfort. In this tech tip, we'll remove
some foam so the seat foam can compress a bit more. The holes are
drilled from the bottom of the seat foam so they don't collect water.
Tools required are pretty simple, but with one "trick" tool, a
home-made hole saw. I haven't tried a store-bought hole saw because
they're very thick and coarse, and might rip the foam rather than
cutting it. Here is the hole saw that I made. It's 5/8" brass tubing
with notches cut with a triangular file:
Start by removing the seat from the bike, then the staples from the
seat cover. I normally lift the staples with a straight screwdriver,
then pull them all the way out with needle-nose pliers. Be careful with
the screwdriver, you don't want to poke holes in your seat cover.
Now remove the seat cover. Remember the orientation and tailoring of
the seat cover so you can reinstall it correctly. It may not be a bad
idea to put alignment marks on them.
Remove the seat foam from the seat pan.
Lay out a grid of lines about 1.5" apart. The grid should be over the thick part of the seat.
Push the hole saw slightly into the foam, then start the drill. This
will make a neat hole. Trying to push a turning saw into the foam
doesn't work very well.
Here's the finished grid.
The stock seat foam was glued to the seat pan, so I glued it again.
Just a bit at the front and back. I figure it will help the seat keep
it's shape. I used weather-stripping adhesive, A.K.A. "Gorilla Snot".
Re-install the seat cover. Pull the cover on, and start at each end,
pulling it snug, but not drum-tight, then hit it with a couple staples.
Next do the middle of each side, then fill in the edges. Check
frequently for wrinkles.
Word of caution, if you're buying a stapler for this job, spend the
money for a good one -- this particular model won't drive the staples
all the way into the seat pan, and I have to beat them in the rest of
the way with a hammer.
If you have any additional questions about seat covering, this tech tip will help:
Seat Cover Install
I've found that this mod gives very nice initial softness &
comfort, but once the holes collapse, it's still firm enough to keep
you off the seat pan, which is an improvement over plain soft foam.
Now go for a good long ride!
