wp 4860 sxs forks on xr
Post  giantpiggy on Fri Oct 16, 2009 1:59 am
Got a set of wp forks for the xr,has anyone got a heads up on what honda triple clamp assembly will be the go for the 650?,crf450?......60mm dia for the bottom triple,and has a xr/crf share 22mm offset?.Thanks
giantpiggy
XR650R Year : 00 0
Re: wp 4860 sxs forks on xr
Post  giantpiggy on Fri Nov 06, 2009 7:15 am
I got the forks on the piggy,just a bit of work finish....got a set of cr500 triples,just had to press the piggy stem into the cr bottom t/clamp,going scotts dampner under bar with risers to get the height up,the cr has 24mm offset,just looking at the number under the piggy t/clamp maybe 19mm offset?....anyway piggy not known for turning traits,just aim and hope for the best sort of rig
giantpiggy
XR650R Year : 00 0
Post  RallyMoto on Sat Jan 16, 2010 12:58 am
Looks good! Got any other pics?
RallyMoto
