Oil Temp Gauge Calibration And Alignment
I calibrated and aligned my "Xr's Only" oil temp gauge...Thought I would share the steps I took.
First I removed the retaining spring from the top of the gauge.
Next I popped the gauge from it's housing...No force was necessary.
Here you can see all the components that make up the gauge.
I measured and scribed a upper fill mark in relation to the stock dip stick. 1-7/8" was appropriate. Notice the 11mm nut on the back of the temp gauge. I boiled water and set the gauge (using the nut to calibrate) to 212 degrees Fahrenheit.
Lastly it's time to align the annoying off centered and for some, upside down gauge. This is real easy since the gauge is still spinning freely in the housing. Tighten the housing nut, set the gauge to top dead center and scribe a line on the housing.
Now reassemble the gauge aligning it top dead center to the mark you made on the housing nut. It should be aligned properly for us picky guy's and calibrated too.
Re: Oil Temp Gauge Calibration And Alignment
Thanks, I need to get this done also. Was the temp calibration off from the factory?
desertfox wrote:Thanks, I need to get this done also. Was the temp calibration off from the factory?
It was close but I had already dinked with it when I was testing how tight the calibration nut was. The temp gauge was already on my bike when I bought it so I thought a calibration was in order.
» Great chain alignment tool
» Thermostat.
» XR's Only Temp Dip Stick
» XR650R Cold Engine Temp
» CARB HEAT SHEILD WRAP. dramatic temp change.
» Thermostat.
