Tire pressure
Tire pressure
Pressures for offroad tires are 1,25 front, and 1,75kPA rear, isnt it.. what about motard tires ? Same ? (at ordinary roads)
thx
thx
Re: Tire pressure
Honda states 15 psi front 15 psi rear.
I run 18 psi in the front and 15 psi in the rear.
Re: Tire pressure
T/p's depend on where & what you ride, and also how you ride on it.
Sand, like dunes? Soft's best, same like in mud...... when there's not rocks or stones.
On rocky surfaces, or hard soil, a harder pressure will not necessarily work better - but the tyres will last better, with less danger of punctures too!
So vary according to the terrain, and real fast pro's will need to up it to prevent flats in nay case.
He said...
He said ordinary roads and motard. He already knows dirt. And there are no dunes in his country according to Google.
Re: Tire pressure
And I said T/P's.
I also said "real fast pro's will need to up it" which, on a circuit, one does by lowering it - as the heat will do the upping then.
So far zero wrong said, contrary to your moaning above.
Anything else I can entertain you with, because your remark clearly comes from an utterly bored person in a bad mood?
» Need tire advise
» steering shake
» Playing with my Knobs
» New BRP owner in savannah ga
» Tire sizes
» steering shake
» Tire sizes
