XR speedo
XR speedo
Post  akasy on Sun Dec 06, 2009 10:44 pm
I'm in the process of getting the BRP street legal and needed a speedo. I'm not a fan of electonic meters so I adapted an XT225 speedo to the BRP--seems to be accurate will test against my GPS later. It does work and was relatively easy.
akasy
I doubt they will even test it
Post  Bump on Mon Dec 07, 2009 5:55 pm
And you won't use it much either! That said, it looks like a sano fit!
I might put a larger washer between the bold head and the bracket. Did you cut the bracket?
Re: XR speedo
Post  Clipity on Mon Dec 07, 2009 8:13 pm
Looks good, I went with the Baja Designs made in China one. I tried the used route (XL350)and ended up with a piece of junk that ended up getting returned.
Clipity
Speedo
Post  akasy on Tue Dec 08, 2009 4:33 am
Bump wrote:And you won't use it much either! That said, it looks like a sano fit!
I didn't have to cut the bracket but I did have to file a very small amount off the lip at its outer edge. I made a bracket to mate to the speedo's peg legs and bolted the bracket to the holes where the original trip meter bolts to the original bracket.
akasy
Re: XR speedo
