decompression issues
Post  qikazel on Sun Dec 27, 2009 8:50 pm
I need help. I went out to the garage to start my xr after a month or so. Is been pretty cold so I figured I'd start her up for a few minutes. All was fine last time I put her away. When I went to start her, I have weak compression. I can kick thru the entire compression stroke without using the decomp lever. Any Ideas?? I cant figure out what could have changed.
qikazel
Re: decompression issues
Post  AURORA on Mon Dec 28, 2009 2:00 am
Check your decop assembly and adjust your valves.
Maybe your pistion rings are worn. Squirt some oile into the spark plug hole. Then with the plug out kick it over a few times.
Post  qikazel on Sun Feb 21, 2010 5:14 pm
Excuse my ignorance but what will this show? Where do I go from there? Thanks.
qikazel
Good Question
Post  Bump on Thu Feb 25, 2010 8:59 pm
waiting...
