My Mods........So Far
Well its still a work in progress but here's what I've done so far.
BRP Tripple clamp, Scott Damper, Pro-Taper Bars, Trailtech 8" Race Light, Cycra Guards, Custom Speedo relocation bracket.
Front view. This shot was taken before the Scott damper was installed. I also had the yellow guards installed in these pics.....Later decided that I prefer the white guards.........I Think . Hmmmm.
Side Shot. Utah skid plate, Acerbis 6 gal tank, Edge 2 tailight (custom license plate bracket), XR's only case saver, Silicone hoses, XR's only chain guide, IMS pegs, ect ect
KTM fan setup. I have this wired into the high beam switch. Nice for those long slow grinds or at long lights.
Hodakaguy
Hodakaguy
Spedo
How do you like the BD speedo? Is it noisy? BTW I like the yellow guards better now also, your light rocks! Nice looking R
Re: My Mods........So Far
Thanks! I haven't had any problems with the BD speedo. It's worked great! The light is a Trailtech unit, I really think it ads to the look of the bike, plus it throws better light than the stock BD light.
Oh yeah.....I keep thinking about re-installing the yellow guards....I think...Maybe not....We'll see....ARGGGG.
Hodakaguy
Hodakaguy
deadly99 wrote:Do you have a part number for the KTM fan?
Not trying to hone in on Hodakaguy's thread but I have the fan bookmarked just in case I add it to my sweaty pig...Click here - www.ktm-parts
If you don't have/use your brights...Wire the fan up to that switch to save you from having to add one.
Looks like Focker got ya the link. Type in KTM fan on E-bay and keep an eye out, I've seen a few new ones go in the $50 range.
Hodakaguy
Hodakaguy
I've added some farkles to mine:
Billet Racing Products Upper and Lower Triple Clamps
Renthal Fat Bars
Kritter Foot Peg Mod
Turbo City Borrego Tail Rack
Utah Skid Plate
Moose Racing Bark Busters
Agri-Supply Tool Tube
XRs Only Case Saver
DRC & Acerbis LED Tail, Brake, License Lights
Now the next item is the tank, I am debating between the Clarke and the Acerbis Sahara. Why did you go with the Sahara tank? 5.8 gals seems like it'll be a top heavy bike...
Renthal Fat Bars
Utah Skid Plate
XRs Only Case Saver
I went with the Acerbis Sahara for a couple reasons. First is we are going to do the OBDR next summer and I wanted a LARGE tank. It does handle a little sluggish when full, although when riding around town you only have to carry a couple gal in it and then its just like the stock tank (weight wise). I also like the looks of the Sahara tank .
It's nice to have that extra capacity when you need it
Hodakaguy
Hodakaguy
Keep in mind that Hodakaguy and Focker like dirt bikes with ape hanger bars and a tank that makes you feel like you are riding a bull. Have you seen there Video?
mamacone wrote:Keep in mind that Hodakaguy and Focker like dirt bikes with ape hanger bars and a tank that makes you feel like you are riding a bull. Have you seen there Video?
High bars are a must when you have long arms The stock bar height is WAY low, not to many people will be able to stand upright with slightly bent arms. My bar setup is about 2.5-3" taller than stock, plus its farther forward thanks to the BRP tripple. I'm 6'1" and can comfortable stand up, very important when doing technical trails, IMHO. I'm running the BRP Submount setup that gives you a 1" rise, plus the Pro-Taper Windham RM Mid bars (Tallest you can get before going to the ATV high bend, and the Windham has less sweep). Bars work perfect for me at this height
As far as the tank goes, The tank looks huge...It is! But......When I sit on a XRR with the clark tank the clark seams to push my knees out farther than the Sahara does. The Sahara doesn't interfear with my riding possition at all, with only a couple gallons or so in the tank the weight is actually lower than with the stock tank. The Sahara tank also gives a little bit of radiator protection as well. You get used to the BIG looks of the tank real quick.
Hodakaguy
Here's an old shot of me on a yamaha...See why I like the tall bars and big tank?
Thanks for your thoughts on the tank. Also, what is meant by the "dry break system" for the Sahara?
Hodakaguy wrote:mamacone wrote:Keep in mind that Hodakaguy and Focker like dirt bikes with ape hanger bars and a tank that makes you feel like you are riding a bull. Have you seen there Video?
Hodakaguy
The "Dry Brake" is a quick fill system for racing, like a spring loaded trap door. Slide into the pits and your crew just pokes the can into the tank and your back off again, no cap. Best just to have the cap to keep the nasties out of the tank for most people.
Hodakaguy
Hodakaguy
Maybe this horn...
Stebel Nautilus Compact Dual-Tone 12-Volt Motorcycle Air Horn, 139 dB in black. http://www.twistedthrottle.com/trade/productview/2137/
I didn't find a spot that I liked for the horn so I just ditched it completely, shortly after I bought the bike.doug@dsa wrote:Maybe this horn...
Hodakaguy
I was blasting bums off the curb with the Stebel I had on my KLR! Loud as Hail, but had to run it through a relay (included) so it takes up some space.doug@dsa wrote:Maybe this horn...
Last edited by Focker on Fri Jan 23, 2009 7:09 am; edited 2 times in total (Reason for editing : this part is stupid)
I was thinking it would be good for my Transalp. The OEM Honda horn sounds like a wounded goose. But then again it still works 22 years later.
» Air box mods
» seat mods
» Count the mods
» road trip mods help
» Former employee of Ballards/XR's Only on racing Mods
» seat mods
» Count the mods
