raising bars: clutch and decomp cable length problems?
raising bars: clutch and decomp cable length problems? Empty raising bars: clutch and decomp cable length problems?
Post  SFXR on Wed Feb 17, 2010 12:04 am
Hey y'all,
I'm raising the bars a lot. Motion pro sells cables 3" longer than stock, but I can't find anyone who makes clutch and decomp cables 3" longer as well. Anyone have this problem? Is there another bike's parts that fit?
Thanks!
Jim
SFXR
SFXR
raising bars: clutch and decomp cable length problems? Empty Re: raising bars: clutch and decomp cable length problems?
Post  Hew on Wed Feb 17, 2010 10:07 am
I recently fitted a Mikuni carb and had to get new throttle cables made for higher bars.
Boats need a lot of cables made up so it could be worth asking local boat yards for cable makers. The other alternative is cable making kits and making one up yourself.
I managed to use the standard clutch and decomp cable by carefully rerouting it. Be sure the decomnp cable does not go tight on full lock as it cuts the engine.
Hew
Hew
Post  modette on Thu Feb 18, 2010 2:37 am
PM pwrtrippin, he raised his bars 5+" He had to get custom cables done up.
modette
modette
http://www.TrailTaker.com
raising bars: clutch and decomp cable length problems? Empty 2 in risers
Post  dos equis on Thu Feb 25, 2010 4:24 pm
I put 2 in risers and a set of Renthal hi bars on and rerouted the stock cables works fine.XX
dos equis
dos equis
Post  modette on Mon Mar 08, 2010 6:35 pm
No room with the big old Acrebis 6.3 Gallon tank. His was pulling the compression cable tight and causing the bike to stall. A real pain in the butt when you had to turn around in a tight spot.
modette
modette
Post  martins315 on Fri Oct 21, 2016 8:43 am
Has anyone solved the problem? Maybe someone have found match from other bikes? Probably replaced with throthle?
martins315
martins315
Post  BuRP on Fri Oct 21, 2016 9:00 am
I got ALL my longer cables made by Motion Pro - they'll make any cable in any length, go ask them!
Post  Mauser on Fri Oct 21, 2016 10:04 am
You could move your carb closer to the front of the bike....thus creating more slack Frustrated or you could ignore my posts...sadly there is no block facility on here razz
Post  martins315 on Fri Oct 21, 2016 3:12 pm
Mauser wrote:You could move your carb closer to the front of the bike....thus creating more slack Frustrated or you could ignore my posts...sadly there is no block facility on here razz
It's always easier to bulshit around then actually help someone listen up
There are some from xronly.com:
http://www.xrsonly.com/xrs-only-extended-throttle-cable-honda-xr650r-00-07-2-inches-pull
Bit expensive for all of them, so will keep looking for alternatives.
martins315
martins315
Post  Mauser on Fri Oct 21, 2016 3:16 pm
This is where in the old days you could take your old cables into a dealership and go through their stock and find a set which are longer.....hard work nowadays mad as heck
Post  BuRP on Mon Oct 24, 2016 7:54 am
Somebody clearly missed my mentioning of
M O T I O N - P R O
in the US, they'll make ANY cable - so, for those wanting to build a stretched chopper out of the Pig..... contact them!
I did too, for 3"-longer cables - which work superb?
Post  SkidMark on Tue Oct 25, 2016 10:49 am
Hey - you can try motion pro, that's where I got my custom length cables from - they will make any cable to any length.
or did someone mention that already... razz
Post  BuRP on Tue Oct 25, 2016 11:06 am
LOL Mark,
yeah, som peepol dont ried wel eh?
Post  Mauser on Wed Oct 26, 2016 7:46 am
I would try Motion Pro myself, shame no one else suggested them listen up
Post  BuRP on Wed Oct 26, 2016 11:34 am
Lol Maus', some prescription glasses for you Squire?
BRP smile
Post  Mauser on Wed Oct 26, 2016 4:54 pm
BuRP wrote:Lol Maus', some prescription glasses for you Squire?
BRP smile
My sarcasm is wasted on you lot !!!!
Post  BuRP on Mon Oct 31, 2016 1:13 pm
Mauser wrote:My sarcasm is wasted on you lot !!!!
Huh?
#thickfaceon
Post  Mauser on Mon Oct 31, 2016 2:07 pm
Huh?
#thickfaceon
Sarcasm
noun
noun: sarcasm; plural noun: sarcasms
the use of irony to mock or convey contempt.
"she didn't like the note of sarcasm in his voice"
synonyms: derision, mockery, ridicule, satire, irony, scorn, sneering, scoffing, gibing, taunting; trenchancy, mordancy, acerbity; rarecausticity, mordacity
"his voice was heavy with sarcasm"
I was mocking your attempt to tell the guy to use Motion Pro razz
Post  PeteN95 on Tue Nov 01, 2016 7:28 pm
From my post in Mod Squad, 3 1/2" risers and tall ATV bars with stock cables, no problems.
raising bars: clutch and decomp cable length problems? Pbucket
PeteN95
PeteN95
XR650R Year : '02
Post  BuRP on Wed Nov 02, 2016 10:48 am
Mauser wrote:... tell the guy to use Motion Pro
Hey, now THAT is a good idea - tell him!
StirPot
Post  SkidMark on Wed Nov 02, 2016 9:42 pm
StirPot
tell him what?  asking for it
Post  martins315 on Tue Jan 03, 2017 3:20 pm
Solved my problem in laziest way possible
raising bars: clutch and decomp cable length problems? LNxCS4bZ8DkLLr2o7yBbubLoB2s6DT0GB8S0dErSTV1-npAni7r-TMNdptFaoMZzxY5AzRzb-ZloYUkYnwr2PMBSbQy5J8WvP8cKdJEJB7SEvE2or0RfGlXZIpaTKiHuB8m9O1qvJC2fNcok06AW1ofu0xG4QgDkCO4HsDGWzmF1IyaoMTwud4QwyXIz3dA6Hn--XZQIS076JifNRMJ40TaNe6XJ9UYzC5q7rmt5k7dRonqHu7dDyMlc8KAaDMupwxrlubxihXyunRtMy9WHo9aXpgaiIn1-MSIctSzXDX6uNxHZZj2w2iBrQ5FCJJvlk2x98T48JgiS2PcOuJVIK0t2woq0zXQCDHy-NmI5iTswm42_zNH434XVjgsD47jkaK_e4pHqLI_dcfGxo_jMCX-ga0u5mfe9HfX7foBDixULfsecwrHMzbDsFOKQCBrEg9kyIASHo7Tm0AsmdE2GVt7JxfCu1Xlynio988ACOsI0QSoP5QVRyV-KSPZYJ3c9B7BP6PSHHXNTpZHbq_-rEZ4pq7wOI6NVnZof7sam0NnwOmwji3IuEbPnE0RyJPXpo6qbe3zediuhqNjIfTE0Z2xnE49HPur9m-sGZmPOiyY9xHhl1Li4=w1027-h770-no
Removed lower nut what gives me even freeplay. Risers are 5cm.
martins315
martins315
