Swinging Arm Refurb
Swinging Arm Refurb
Out of boredom I brought this off fleabay, adjusters were seized !!!! wow never expected that to happen !!!! got to be a first
Anyway the 1 came out fairly easily but the other was a right sod.....24 hours later with help from some penetrating oil and heat it came out.....
Moving on to the bearings 1 side was terrible.....
Collar was as bad...
Found some bearings on fleabay which are the same as fitted..TLA2520Z. 25x32x20
Now question is what about the inner seals ?......I can find some 25x32x4mm Nitrile Rubber Rotary Shaft Oil Seal on fleabay....
http://www.ebay.co.uk/itm/131695965000?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Will they be OK ?.....Honda wanted £140 for 4 bearings, 2 inner seals and the 2 collars
Not sure what I will do with the arm when finished it's great condition on the chain side but few blemishes in the anodising on the other side....shame really
Re: Swinging Arm Refurb
Hey Mauser, found this on fleabay its located your neck of woods not sure if you searched this but price is better than Mr. Honda's!
http://www.ebay.com/itm/Honda-XR650-R-2000-2007-ALL-BALLS-Swingarm-Linkage-Kit-/291876531636?hash=item43f5326db4:g:hhwAAOSwCGVX28Bg
Saw that but being tight and this only being a project I am robbing a collar from friend and just looking at new bearings (fleabay) and it's the seal I was pondering ?
Cheers for looking
Cheers for looking
Wonder why there are no outer dust seals ?, there is room when the 2 bearings are in place ? might bang another couple in between the outer larger washer and the first bearing....
