Selfmade cockpit for a trailtech vapor
Post  rikco on Sat May 08, 2010 5:05 pm
I found a piece of plastic @ work and i had an idea
i made it like this only thing left is the wiring for all
what yall think about it?
i think its great
tomorow i need to make the new chain fit then im able to ride the brp again but now in sm mode with sprockets 14-51 (before 14-50)
rikco
Re: Selfmade cockpit for a trailtech vapor
Post  Focker on Sat May 08, 2010 5:24 pm
I like it but...It's missing the oil slick and smoke screen switches.
Nice job!
Helpful Tips:
Image Posting
XR650R Forum Search
Focker
Site Owner
http://www.xr650rforum.com
Post  rikco on Sat May 08, 2010 5:33 pm
thnkz Focker
the switch you see is for the cooling fan i build on some time ago
rikco
Post  bikerman on Wed May 18, 2011 1:17 am
Rikco is that Trail Tech Vapor that they have on ebay for 98 US dollars? I couldn't see the pics, file was too big? can you send some pics to my e mail?
Thanks,
IBM
rikco wrote:I found a piece of plastic @ work and i had an idea
i think its great
bikerman
Post  rikco on Wed May 18, 2011 1:55 am
yes its the trail tech vapor + the single dashbord from e-bay.
dunno exactly what i payd but it was close to 150 dollar for all. (vapor + dash)
the rest i made myself
Wink
rikco
Post  bikerman on Wed May 18, 2011 2:02 am
Nice Job! so you use the Vapor as a odometer? did you have the stator conversion? how many watts 250? I see that you have a 12Volt outlet like the one in the cars, is it? How did you do the wiring, was it hard? I am not that good at complicated wiring diagrams but I want to do mine. How much did you spend doing all the dual conversion kit? Please do you have a list what I need to buy?
Thanks,
Ivan
rikco wrote:yes its the trail tech vapor + the single dashbord from e-bay.
Wink
bikerman
Post  rikco on Wed May 18, 2011 3:27 pm
no other stator then the original 75watt (european model) a 250watt i never seen for the xrr, max stator output is a 200watt as far i know.
my piggy was already factory made for dual sport so i did nothing else then add some small blinkers, led tail&brake light and the vapor and 2 12volt car connectors.(1 you cant see)
wired it from inside the headlight switch and with the headlight off i still got 12volt power on that cable.
here you can see the vapor, this was the first ride when the snow was gone 2 months ago so nothing special pirat (gearing 13/52 Twisted Evil )
https://www.youtube.com/watch?v=Y1IlS6mhq8Y
https://www.youtube.com/watch?v=NRtxLXupzK4
Cool
rikco
Post  bikerman on Wed May 18, 2011 9:35 pm
Rikco did you get the one with the Key or you got the key separate ?
Ivan
rikco wrote:no other stator then the original 75watt (european model) a 250watt i never seen for the xrr, max stator output is a 200watt as far i know.
Cool
bikerman
Post  rikco on Wed May 18, 2011 10:30 pm
dunno anymore where i got the key switch from, it didn't come with the vapor but on e-bay there are enough on/off key switches that works the same.
http://cgi.ebay.com/Electronic-Key-Switch-on-off-/320700424033?pt=LH_DefaultDomain_0&hash=item4aab3c1f61
rikco
Post  bikerman on Thu May 19, 2011 2:51 am
Rikco,
My bike when the PO bought it from the Dealer they fit it for the street as a dual purpose so that's mean may be mine is already with a factory stator? how do you know how many watts is coming out of my bike stator? any way to measure it?
bikerman
Post  Mauser on Thu May 19, 2011 8:13 am
bikerman wrote:Rikco,
Pull the stator cover and see how many of the windings are used.
Post  bikerman on Thu May 19, 2011 10:17 pm
Rikco,
How did you conect the Vapor to the original cable from the odometer? does it come with the port to conect the original speedometer cable?
bikerman wrote:Nice Job! so you use the Vapor as a odometer? did you have the stator conversion? how many watts 250? I see that you have a 12Volt outlet like the one in the cars, is it? How did you do the wiring, was it hard? I am not that good at complicated wiring diagrams but I want to do mine. How much did you spend doing all the dual conversion kit? Please do you have a list what I need to buy?
Thanks,
Ivan
Wink
bikerman
Post  BuRP on Fri May 20, 2011 8:35 am
Yo Guys,
regarding the keyswitch (ignition switch) following.
I also bought one, nice to have, prevents thieves from a quick getaway. But, this switch is a single contact only, meaning you can switch 1 circuit only, and my plan was the ignition.
If you've got a battery (a DC system) then you've got a problem, all will still work until the battery is empty, you don't want this. So I found a dual-circuit keyswitch, which kills the ignition as well as the DC-circuit, meaning the bike is really 'off' when the key is out - which I presume you want! So no fiddly system with a relay required or why, just a single key which does all.
I'll look for the link once at home, but Google should be your friend.
Post  rikco on Fri May 20, 2011 7:54 pm
Rikco,
not this is digital, it comes with all you need.
Wheel Sensor
Magnet
Temperature Sensor: 16mm Radiator Hose Insert
http://cgi.ebay.com/ebaymotors/Vapor-Striker-Trail-Tech-Motorcycle-Indicator-Dashboard-_W0QQcmdZViewItemQQhashZitem35b2358d66QQitemZ230623120742QQptZMotorcyclesQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Trail-Tech-Vapor-Speedo-Tach-Computer-Honda-XR650R-_W0QQcmdZViewItemQQhashZitem4cf0df0f59QQitemZ330458664793QQptZMotorcyclesQ5fPartsQ5fAccessories
rikco
Post  bikerman on Sat May 21, 2011 2:48 pm
Thanks Rikco, I just Bought it.
bikerman
