Need Help
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Need Help
Hi Burp,
Yes I can use epoxy on the 5mm screw, thanks.
As the carb is not mine, it is borrowed, and the owner said he was working well, just needed the rubbers, o-rings etc… .. so I kept the configurations, and i did not use epoxy on the air cut valve hole, also.
My goal its with the spares I have try to fix my carb and swap it again, to see how it works…
Meanwhile, Probably I’ll buy this carb, (because this it working fine) than I’ll upgrade main jet to the 178.
Yes I did search around for the correct float-level setting, service manual says 16.0mm I set it on 18.0mm, its ok, no leaks at all.After replace the mixture screw again, did set it 2.0 turns (old mixture screw had 2.0 turns), but i´ll do as you say, around 1.5 turns.
I am assuming that the problem was really the carb, otherwise no idea at all, where was the problem.
Promise, i´ll give you feedback, just need time also, at same time i am rebuilding my old nx650 dominator 1990..
Once again, thank you all
Re: Need Help
Gentleman,
Swap done from 175 to 178 (main jet)
Now i have:
Low jet 68S, 178 and 3rings from top.
idle mixture screw +- 1.5 turns.
Front/Rear sprocket 14/40T
Tires Bridgestone 120/70/R17 & 140/70/R17
Really gooooooood.
Going to leave it this way.......
Next job..... Am buying more spares to rebuild my old carb, than Swap it again to see if works or not.. (want to be sure, what was the that stuck idle problem)
thank you all.
Regards
Now i have:
Really gooooooood.
thank you all.
Regards
Re: Need Help
As I said put it back to stock lol, no need to re-invent the wheel. Glad your sorted.
Re: Need Help
Ian,
if you will keep this bike for a planned long time then best to buy a few 'more' parts for the carb for the future, just in case.
Reason is this bike's getting old, carb ditto but the parts are still available now.... but that will change.
Having a few spares is better than looking for them, or having to make do with 2nd hand scrounged one's
Enjoy this bike, it's a great one (... which Honda should have developed further etc etc but they did not
Re: Need Help
..Yes in Europe its not easy to find spares for the BRP.
Am planning to keep both carbs... and want to try both, am just wait for a new slow jet 68S, lost it somewhere in my garage...... am mad!!!!! than will swap carbs again to see performance.
Regards
Regards
Re: Need Help
Gentleman,
Ordered a #68S (ebay) received a 68.
Honda dealer do not have code (Part Number) for 68S only 99105-MBN-0680 (#68)
A guy told me for the #68S, the PN its H099105-MBN-0680 (honda dealer do not have this PN).
I saw pictures and have in my first carb, a Keihin slow PILOT jet with the Keihin symbol stamped and 68S.
So, This exists as original Keihin? #68S
Does anyone of has a spare to sell?
thanksss
thanksss
Re: Need Help
Here what I purchased for my US restricted bike...
16211-MBN-640 CARB ISOLATOR £14.50
99101-357-1750 #175 MAIN JET £10
16012-MBN-641 MAIN NEEDLE £26.50
99105-MBN-0680 SLOW JET £11
Re: Need Help
Mauser, thanks
I also bought the same items as you...
But, do you to know....if that infamous slow Jet "68S"...its real, or someone fake it, and say original its Honda?
Re: Need Help
I orderd the parts from my local dealer....all genuine and 68Slancap wrote:Mauser, thanks
Re: Need Help
Ok, thanks,
I already went to the Honda dealer (Portugal), they told me PN 99105-MBN-0680 stands for the regular 68.
as you may see by the picture.
But this time i ordered one, maybe i´ll get the S..
I have to wait and see..
Re: Need Help
Glad you got the right 1....
Re: Need Help
Well......., after all this time, bought more spares to rebuild my previous carb (the one came with BRP)… .and found time to swap carbs again........another big disappointment.
As soon as I fitted, warmed up engine, before leaving garage… old same problem .. hanging revs… at 1700-2000rpm
Do not know what previous owner did …… but definitive it’s a carb problem….
Gave up, and Am using the second....not so powerful at high revs, but it work.....
I do not know because the carbs references are difference if makes any difference....on performance.
Regards
Regards
Re: Need Help
You would think that's impossible if the thottle is closed how can she rev to 1700 ?must be getting fuel from somewhere to run at the higher rpm ?...unless she running really lean ?
Re: Need Help
..sorry, forgot:
.....as soon as i pull the throttle, the rpm stays at 1500-1700 rpm, need to pull the throttle several times to get it down. When i bought the bike it came like this.. always had problems to get to idle...rpm.
Am using the same settings as the other carb....
Page 2 of 2 • 1, 2
Page 2 of 2
