should I wrap or coat my header pipe?
Hey guys,is there any advantage to wrapping or coating your head pipe? Mine is lookin like crap and heat paint does'nt last.
Wrapping is wrong
Header pipes were never engineered to be wrapped.
I called several people about this a few years ago. The best information I got was from two engineers at Pro Circuit. The nutshell version is this:
The pipes are engineered to be as thin and light as possible. Wrapping them holds heat in and gets the pipes far hotter than they were engineered to withstand. The pipes will fail much sooner. In fact their Ti pipes are only engineered for a race or two.
I called an engineer at Thorley (my dually has coated Thorley headers and I posted this whole story in a longer version on here elsewhere). He took my T-4 pipe and had it run through with a batch of their headers at an aerospace company in LA. I taped off the male side of the slip fits and that was all. I think the cost was about $70.
The coating is a resin mixed with aluminum dust.
Welcome friends!
The work I had done at Thorley came out very good. I searched online first and found a lot of people had problems with jethot FYI.
» For anyone that Jet Coated their header pipe.
» TB's 650
» DG pipe
» which exhaust?
» FMF Header hitting radiator?
» TB's 650
» DG pipe
» which exhaust?
