What does the XR650R need?
Page 1 of 2
Page 1 of 2 • 1, 2
Focker: Please feel free to move this as I really didn't know where to put it?
Fellow BRP owners: Dual Sport Armory is trying to brainstorm about coming up with something to make/machine for the BRP. Something that has not necessarily been created yet. I hate to use the term "farkle"....but you know like a farkle.
Without pre-tainting the pool please give your 2 cents about what our already perfect bikes need? The skies the limit! Thanks for any help.
Re: What does the XR650R need?
Replacement heavy duty rear sub frame for hauling camping gear?
Hodakaguy
Hodakaguy
Heavy duty replacement clutch cover, aftermarket replacement brake pedal.
Not going to go there.husky123 wrote:Focker: Please feel free to move this as I really didn't know where to put it?
I know it's not machined but bolt on plastic fork guards would be sweet.
Damn good stuff guys! Keep 'em coming.
Oh and Focker I did throw you a softball huh?
Focker wrote:I know it's not machined but bolt on plastic fork guards would be sweet.
+1 on that!
Hodakaguy
Stand alone decompressor lever bracket that you can mount anywhere when using an aftermarket clutch perch and you dont want a combined unit. (right side or left side).
Some form of BIG radiator guard, like a piece on angle iron that bolts on under the bottom of the rods to stop the caving in/moving back.
I've got the acerbis sahara tank supports, and some rad braces, but a couple og pounds of iron would make me feel better!
We get an extra metal bit that runs under the rear light, good for enough "xr" luggage - 3/4 days easy.
stroupdog wrote:Stand alone decompressor lever bracket that you can mount anywhere when using an aftermarket clutch perch and you dont want a combined unit. (right side or left side).
What stroupdog said.
Hey guys, some of your "I wants" are already available.
Acerbis makes a plastic fork guard for the XR400 that will work with a small modification.
http://www.onoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ACER-HONDA-FORK-COVERS-UPPER-STD&Category_Code=ACER-HONDA
Pics on a XR650R here: http://www.advrider.com/forums/showthread.php?t=334755&highlight=xr400+fork+guard
The XR250R has a seperate decomp lever that should work on the 650R either left or right side. I also thought about using a hot start lever setup like from Dubach or Works Connection. I am nor sure why you need a decomp lever though. I dont use mine...ever.
Heavy duty clutch cover cover.
http://www.motorcycleproducts.org/Engine_Guards/guards-main-frameset.htm
Wolfman luggage has come up with dual sport specific soft luggage. No mounts needed. Combined with the Enduro tool kit, you have a lot of storage space! You can get them from .....Me. www.dualsportarmory.com for $117 shipped
http://www.wolfmanluggage.com/Enduro/EnduroSaddleBags.html
Doug wrote:Hey guys, some of your "I wants" are already available.
Pics on a XR650R here: http://www.advrider.com/forums/showthread.php?t=334755&highlight=xr400+fork+guardddleBags.html
Do you know where you can get a pair? I thought they stopped making those?
Hodakaguy
Doug wrote:Did ya click on the link?
Yep I did and it said "DISCONTINUED"......glancy.
How about a better way to grease the swing arm linkage? Just suggesting...
I'm sorry...I want lower guards.
Me too...instead I wound up buying these sticker-type guards for $9.99 (I couldn't find anyone that still stocked the old XR400 lower guards the would've fit)...I'll post to show once I get them in and judge them:
http://www.motosport.com/dirtbike/product/NSTYLE-CARBON-LOOK-FORK-PROTECTORS/?prodId=79687&sMMY=
Focker wrote:Doug wrote:Hey guys, some of your "I wants" are already available.
Husky to the XR courtesy phone.....
bust out a picture of your LOWER fork guards.
I know somebody here has them but they're like a $100 bucks or something...Too much coin for me.
Yep mine are the Precision Concept dilly yo's. About a hunsky.
Those are it...Yeti has them too.husky123 wrote:Yep mine are the Precision Concept dilly yo's. About a hunsky.
I'm partial to the big obvious ones like the dirt bikes use. Here they are on Pikkos' converted fork setup.
Thumpmeister wrote:How about fuel injection?
I'll get right on it.
What is the trick to starting it with out the decompresser lever?Doug wrote:Hey guys, some of your "I wants" are already available.
Yeah, this would be good to have.AtomicXRer wrote:How about a better way to grease the swing arm linkage? Just suggesting...
mamacone wrote:What is the trick to starting it with out the decompresser lever?Doug wrote:Hey guys, some of your "I wants" are already available.
I just kick through until I find TDC and BAM. I have a Edelbrock on the bike, but dont think that matters.
Husky, do you use yours?
Page 1 of 2 • 1, 2
» How to check oil pressure after oil change
» my xr650r
» REVENGE BAJA RACING TEAM
» my xr650r
Page 1 of 2
