Trail Tech Vapor for XR650R
Hello all!
I love reading through all the older posts, and getting up to speed on this great bike!
I have gotten my BRP all legal and happy, but the Trail Tech Panoram died, and I just purchased a new Trail Tech Vapor, and hope to install it very soon, and have some questions for the resident experts on here.
What is the best position to install the magnetic pick up for the speedometer? I am having trouble finding a good position to get it secure and close enough to read the magnet.
And it is asking for "Pulses Per Revolution" (PPR). It lists the default for a 4-stroke as1PPR. I assume this is correct with the XR650R engine.
Also what are the correct settings for the:
High temp Warning point
Over temp danger light
RPM Shift indicator
And while I am here, where should normal operating oil temp be? I have a XR's Only dip stick temp gauge and wonder what is normal.
As this is a relatively new bike for me, any guidance info would be greatly appreciated!!
Thanks again, and I hope to see you guys out there riding!!
Steve
Over Shift indicator
RPM Shift indicator
Steve
Re: Trail Tech Vapor for XR650R
Not sure but you might like this:SwellsRides wrote:And while I am here, where should normal operating oil temp be? I have a XR's Only dip stick temp gauge and wonder what is normal.
Link - My Calibration Fix
» Trail Tech Vapor power question
» Steering damper/Trail Tech mounting questions?
» The trail tech puter
» Trail Tech Tachometer installation
» Harness from a 650L fit 650R ?
