The trail tech puter
The trail tech puter Empty The trail tech puter
Post  Guest Tue Mar 10, 2009 8:19 am
Started the install today and I have to say the plastic mount is cheap and wont work. Since Im a sheet metal guy by trade I made my own mount. When I came to the power wire hook up part I really didnt understand the hook it to the stator part.
Instead of going that route Im going to get into my RC car batterys and make a pack for it. Found a place on the bike to mount it so thats not a problem.
Ill let you know how it works out naughty
The trail tech puter Empty Re: The trail tech puter
Post  Guest Wed Mar 11, 2009 3:03 am
I spliced into the running light on my BD d/s headlight for the power source on mine. listen up
Post  Guest Wed Mar 11, 2009 4:07 am
I never thought of that and its right there beat head
Post  Guest Sat Mar 14, 2009 8:06 am
The trail tech is installed on the pig except the speedo. Instead of that part I changed the coolant and the oil then went over the bike tightning everything. The speedo should be in this weekend.
Ill try it out this week
Post  Guest Wed Apr 01, 2009 7:44 am
Took longer than planned but its done.
The BRP
The trail tech puter Picture016
Mounted
The trail tech puter Picture014
The coolant sensor. I chose this hose because it was easy to get to. It may change
The trail tech puter Picture015
Instead of drilling the rotor I found a hole that was almost the right size for the speedo magnet.
The trail tech puter Picture017
Ill get the billit protector later but for now this works
The trail tech puter Picture018
Post  Guest Tue Apr 28, 2009 12:40 pm
I'm just about to order one so I'll be watching for your observations. Thanks for posting 2 thumbs
Post  Guest Mon May 04, 2009 7:36 am
When you do install it I found the magnetic bolt they supply wont work. It was the easy way so I tried it first. I used the speedo sensor magnet they supplied in a slot it would fit in tightly. Took a few tries but it should fit in one of the factory slots. It took a little tapping with a hammer to get it to seat.
