rear suspension
rear suspension
hi I just bought my XR650R and I'm 5'10. I'd like to lower it a one to three inches... what is the easiest way to do this? I know I can just compress the rear spring with the two lock rings, will that get me enough? Is there a better option out there?
Re: rear suspension
HELLRAISER wrote:hi I just bought my XR650R and I'm 5'10. I'd like to lower it a one to three inches... what is the easiest way to do this? I know I can just compress the rear spring with the two lock rings, will that get me enough? Is there a better option out there?
You could lower front suspension adjusting it on triple clamps by about 1" or so.
If you just compress rear spring you don't get much of suspension.
You could change rear suspension linkage. It's cheap but won't get the best suspension...don't know your needs.
I wouldn't change a think (easy for me to talk as i'm about 6'1" ) ...know a lot of guys some with 5'5" that can't touch even one foot on the ground...where I slow down to try to pass some obstacle they just keep on going. Some times they are lucky some do not
Some reading:
http://www.sportrider.com/tech/146_0210_lowering_your_bike_safely/viewall.html[img][/img]
Re: rear suspension
I think you need to slacken the suspension nuts as this makes it softer and will sink more letting you touch the floor.....I maybe wrong however
R/SHOCK
I HAD A SPACER PUT IN MY REAR SHOCK, IT REDUCES THE TRAVEL SLIGHTLY, IT WAS REVALVED AT THE SAME TIME SO IT SUITED THAT SET UP, GIVES ME ABOUT AN INCH LOWER SEAT HEIGHT
Re: rear suspension
Mine is quite a bit lower than OEM with the 17" wheels and 20mm dropped yokesrikco wrote:Get some 17inch rims
must be low enough by then
Re: rear suspension
Was this for your motard? How big spacer? Where does it go? (see pic below).temporary kiwi wrote:I HAD A SPACER PUT IN MY REAR SHOCK, IT REDUCES THE TRAVEL SLIGHTLY, IT WAS REVALVED AT THE SAME TIME SO IT SUITED THAT SET UP, GIVES ME ABOUT AN INCH LOWER SEAT HEIGHT
At the moment the most I can drop the front is about 20mm as then the handlebars are in the way of the forks coming up higher
Going to strip my shock soon (maybe tomorrow) but have to order parts from USA on Monday (may not have shock stripped by then). Are there any parts I should order? Bladder? Anything else?
Ordered fork seals and dust seals for my forks - The 4 sliders are still ok.
Re: rear suspension
Will make a huge difference, my friend who's vertically challenged could touch the floor on my bike when I first got it with 17" rims.....13/90/18 soon stopped him lol.AURORA wrote:+1rikco wrote:Get some 17inch rims
Re: rear suspension
hang on a minute...I'm 5' 10" and yes it is a bit of a stretch getting a leg over (the bike) but once on and it settles I can easily touch the ground. Now do I have soggy suspension or is yours too stiff...I would check your adjustments first and set it up properly before trying to lower it.
Regards
Regards
Re: rear suspension
it must go on top of the rod guide[or under] to stop the piston delivering full strokeChris_w_65 wrote:Was this for your motard? How big spacer? Where does it go? (see pic below).temporary kiwi wrote:I HAD A SPACER PUT IN MY REAR SHOCK, IT REDUCES THE TRAVEL SLIGHTLY, IT WAS REVALVED AT THE SAME TIME SO IT SUITED THAT SET UP, GIVES ME ABOUT AN INCH LOWER SEAT HEIGHT
Re: rear suspension
I believe I should replace the rod guide when rebuilding the shock. Is this correct?temporary kiwi wrote:it must go on top of the rod guide[or under] to stop the piston delivering full strokeChris_w_65 wrote:Was this for your motard? How big spacer? Where does it go? (see pic below).temporary kiwi wrote:I HAD A SPACER PUT IN MY REAR SHOCK, IT REDUCES THE TRAVEL SLIGHTLY, IT WAS REVALVED AT THE SAME TIME SO IT SUITED THAT SET UP, GIVES ME ABOUT AN INCH LOWER SEAT HEIGHT
rod guide
yes id replace it as it contains the seal, the bladder as well if its been in there a while, i beleive from memory the spacer was 10mm thick, but was then halved, with this i can just put one foot on the ground[ im only 5"7] another way to work out how much you will lower it is to divide the std shock stroke [ easy once you've removed the oil/gas] by the full suspension travel[307mm from memory] then you will be able to get the thickness right for your desire
» XRR Suspension
» Need Suspension Help for one BIG Dude
» Suspension Guru's
» SOFT SUSPENSION
» XRR Suspension
» Suspension Guru's
» SOFT SUSPENSION
