Starts without choke
Page 1 of 1 • Share •
My 2004 xr650r starts without choke very easy 1st kick, drilled out tip exhaust stage 1 cam thats all.. 68s pilot 168 main needle 3rd clip
Sea level, 25 deg c..
Fuel mixture screw 2 turns out
If I give the bike a bit of a floggin and stop at the shops it can be a real pain in the butt to start.
Seems to pull hard but if I turn the fuel screw in more say 1 1/2 turns out I get a flat spot and stalls
My question, am I running a too rich pilot as the no choke starting would suggest??
are the Mikuni TM 40-6 carbs worth the money??
When I got the bike It had A 65 Pilot and a 162 main and I could not start the bike..
xrmick- L Rider
Re: Starts without choke
Try 1 size smaller pilot jet and use choke to start the bike , also your main jet size sound small to me for your elevation ( most people run 175 or there around ) , every bike is slightly different and what works for mine will not work on yours , you need to buy couple of jets and try what works for you , als a good idea to refresh the carb with new gasket set ( seals ) and float valve .
Or you can do what some of us did after we got fed up with the stock carbie , get your self a mikuni tm 40 ( or keihin FCR41 )
Some lads are happy with the stocker ( Mauser
) , fair enough if yours work .
Mad Frosty- XRR Monger
