Oill filter spray vs liquid
Spray or liquid?
I've been using spray because it's cleaner but not sure which is better.
For those using spray how do you do your air filter oiling?
Re: Oill filter spray vs liquid
I just lie the filter on a piece of paper and spray with the oil ?
Mauser wrote:I just lie the filter on a piece of paper and spray with the oil ?
Yep, also do that both sides after I do some filter "massage"
But how eficiente is spray compared to liquid oil filter (introducing filter and oil in a plastic bag and massaging?
babuja wrote:Mauser wrote:I just lie the filter on a piece of paper and spray with the oil ?
For my normal green laning the spray is fine I am sure....if I was doing heavy dusty stuff then you won't beat the oil in bag treatment
» Piston oil spray jet
» Liquid containment fuel bladders
» Engine sounds
» New to your forum
» Stuck Valve
» Engine sounds
» New to your forum
» Stuck Valve
