raising bars: clutch and decomp cable length problems?
Hey y'all,
I'm raising the bars a lot. Motion pro sells cables 3" longer than stock, but I can't find anyone who makes clutch and decomp cables 3" longer as well. Anyone have this problem? Is there another bike's parts that fit?
Thanks!
Jim
Thanks!
Jim
Re: raising bars: clutch and decomp cable length problems?
I recently fitted a Mikuni carb and had to get new throttle cables made for higher bars.
Boats need a lot of cables made up so it could be worth asking local boat yards for cable makers. The other alternative is cable making kits and making one up yourself.
I managed to use the standard clutch and decomp cable by carefully rerouting it. Be sure the decomnp cable does not go tight on full lock as it cuts the engine.
PM pwrtrippin, he raised his bars 5+" He had to get custom cables done up.
2 in risers
I put 2 in risers and a set of Renthal hi bars on and rerouted the stock cables works fine.XX
No room with the big old Acrebis 6.3 Gallon tank. His was pulling the compression cable tight and causing the bike to stall. A real pain in the butt when you had to turn around in a tight spot.
Has anyone solved the problem? Maybe someone have found match from other bikes? Probably replaced with throthle?
I got ALL my longer cables made by Motion Pro - they'll make any cable in any length, go ask them!
You could move your carb closer to the front of the bike....thus creating more slack or you could ignore my posts...sadly there is no block facility on here
It's always easier to bulshit around then actually help someoneMauser wrote:You could move your carb closer to the front of the bike....thus creating more slack or you could ignore my posts...sadly there is no block facility on here
There are some from xronly.com:
http://www.xrsonly.com/xrs-only-extended-throttle-cable-honda-xr650r-00-07-2-inches-pull
Bit expensive for all of them, so will keep looking for alternatives.
martins315 wrote:It's always easier to bulshit around then actually help someoneMauser wrote:You could move your carb closer to the front of the bike....thus creating more slack or you could ignore my posts...sadly there is no block facility on here
This is where in the old days you could take your old cables into a dealership and go through their stock and find a set which are longer.....hard work nowadays
Somebody clearly missed my mentioning of
M O T I O N - P R O
in the US, they'll make ANY cable - so, for those wanting to build a stretched chopper out of the Pig..... contact them!
I did too, for 3"-longer cables - which work superb?
M O T I O N - P R O
Hey - you can try motion pro, that's where I got my custom length cables from - they will make any cable to any length.
or did someone mention that already...
LOL Mark,
yeah, som peepol dont ried wel eh?
I would try Motion Pro myself, shame no one else suggested them
Lol Maus', some prescription glasses for you Squire?
My sarcasm is wasted on you lot !!!!BuRP wrote:Lol Maus', some prescription glasses for you Squire?
Mauser wrote:My sarcasm is wasted on you lot !!!!
Huh?
#thickfaceon
BuRP wrote:Mauser wrote:My sarcasm is wasted on you lot !!!!
Huh?
#thickfaceon
Sarcasm
noun
noun: sarcasm; plural noun: sarcasms
the use of irony to mock or convey contempt.
"she didn't like the note of sarcasm in his voice"
synonyms: derision, mockery, ridicule, satire, irony, scorn, sneering, scoffing, gibing, taunting; trenchancy, mordancy, acerbity; rarecausticity, mordacity
"his voice was heavy with sarcasm"
I was mocking your attempt to tell the guy to use Motion Pro
From my post in Mod Squad, 3 1/2" risers and tall ATV bars with stock cables, no problems.
Mauser wrote:... tell the guy to use Motion Pro
Hey, now THAT is a good idea - tell him!
tell him what?
Solved my problem in laziest way possible
Removed lower nut what gives me even freeplay. Risers are 5cm.
» Clutch/decomp lever options
» clutch cable???
» Speedo Length
» Clutch problems in 2002 XR
» clutch cable???
» Speedo Length
