Good Article On Case Saver and more
Borynack delivers again with this great and brief page on case savers:
http://borynack.com/XR650R/Cycle/difference_between_case_savers.htm
Re: Good Article On Case Saver and more
im about to install mine on the brp
its a selfmade saver by a well known member on xr forums
its a nice piece
now i dont have to worry about a broken chain
its a nice piece
Nice piece!
Looks great. Just an FYI, Team Honda always ran the OEM guard. It works perfect with the 14 up front and a small amount of grinding is all that is necessary for a 15. IMHO, the key to safety here is to change the chain at regular intervals. Use the stock Honda chain too. You have to spend a lot of cabbage to beat the Honda chain.
I'm always amazed at the amount of preventable crashes and catastrophic failures of parts that are the result of running parts too long. Change cables, tires, chains, oil and so forth regularly. It's cheaper in the long run. The bike will be cheaper to maintain and be worth more when you sell it. Sell your used stuff for emergency spares.
hi there, I wish to make one similar,
could you kindly send me the draw of it 1:1 (original size) and its
various sizes, including thickness?
Can it be mount with 15 teeth sprocket? Of what metal did you made it?
thank you however
best regards
thank you however
best regards
rikco wrote:im about to install mine on the brp
its a nice piece
hey hey hey ...
surpriserider wrote:has anyone seen one for a 16 tooth sprocket?
Mine (the one on the pics above) fits with a 16.
I was hoping to buy one because I have way too many projects already but it looks like I'll have to make one like yours. That's a nice looking case saver
various
sorry but i dont do that cause i did not make it.
ask the man who make them and he can send you a draw of it for 50 dollar
» Download The Old Dirt Bike Mag. Article on MX Racing the BRP
» Older but interesting article on Airboxs including BRP
» Welding Safety
» Interesting article on body armor research
» Welding Safety
