Beaver from OZ
Beaver from OZ
I think i got this pic posting sorted out duhhhhhhh , pics of the xr not a beaver.
Oh yeah it worked,
Oh yeah it worked,
Re: Beaver from OZ
And by the way, the tittle is a little misleading..... I mean I do like beaver.
Re: Beaver from OZ
Nice, looks like its been sitting in someones shed for the last 10 years..
Re: Beaver from OZ
Thanks for the feedback gents, i do try to keep it presentable.Armor-All and WD40 and some rags does wonders. Your almost right there ZORO, it sits under a bike cover in a carport most of the time, only ridden on sundays (true) Xrsaylor01 i'm not sure if you mean headlight or taillight but both are standard, the small light on top of the rear guard is not wired so does not work, it would not meet roadworthy here so that is why the other light is under the rear guard. Just for some useless info. in 2004 these bikes sold for $9000 AUD ,that was ride away,uncorked at the dealer,all tax and duties paid, KTM640 hand grenade was about $12500-$12800 and Yamaha TT600 was around $8000 or there abouts. Other makes i can't remember, too long ago At the time the KTM was meant to be faster but had a reputation of going BOOOOMMMMMMMM so i think i made the right choice
Re: Beaver from OZ
Mad Frosty wrote:Clearly There is no salt used on the roads in QLD
And no pepper
Re: Beaver from OZ
beaver350 wrote:Xrsaylor01 i'm not sure if you mean headlight or taillight but both are standard, the small light on top of the rear guard is not wired so does not work, it would not meet roadworthy here so that is why the other light is under the rear guard.
I'm sorry I had momentary memory loss. I forgot the AUS models came with a speedo, blinkers, and a horn. Here in the US we've got to jump through hoops to get 'em street legal. I had to add a speedo, horn, and brake light switch. I don't have blinkers installed, I just use hand signals. I do have a turn signal kit i plan on fitting at some point, but I need an upgraded stator first.
Re: Beaver from OZ
You could try using LED blinkers, most auto parts shops sell them here, i guess there is the same, that would be more forgiving on your electrical system, and stick with the trumpet hornXrsaylor01 wrote:beaver350 wrote:Xrsaylor01 i'm not sure if you mean headlight or taillight but both are standard, the small light on top of the rear guard is not wired so does not work, it would not meet roadworthy here so that is why the other light is under the rear guard.
