tech question
tech question
had my brp 2000 for a year, when i back it off then give it a gut full at low revs it stalls, had the carb looked at, seemed alright any ideas on what it could be????
ps done lots of klm, still seems fresh.
Re: tech question
Sounds about right for a stock carb....this is why some upgrade to the pumper carb
If your like me and ride around @ 30mph in 5th all the time there is no problem lol
Re: tech question
Thanks Mauser geared 15/43 cause I like the tarmac as well.Still hard to take half way up slippery hill with ruts .The other one I rode seemed little less aggressive but I couldn't get that to stall out even when I tried. Thought it might be the jetting?
Re: tech question
Could be mine is geared 13~50 which is pretty low but I like it . Some of the others might have a better idea of the problem....they just not awake yet
Re: tech question
15/43?
What is your top end speed? 200 mph?
Your gearing has a final ratio of 2.87 The stock final ratio is 3.36
Is your bike a motard with street tires?
With that gearing you cannot wack the throttle and expect the engine to respond, unless of course the diameter or the rear wheel assembly in a smaller diameter than the stock rear wheel to accommade your current gear ratio.
You have no accelerator pump on your carb. It is a roll on carb.
owners manual
I got a little hand sized owners manual with the bike page 80 standard sprocket size engine 15 rear wheel 41. thought I wasn't going to crazy adding a couple to the back .Even at speed got a real on of feel . wont do 200 wurst luck.
Re: tech question
madkate wrote:I got a little hand sized owners manual with the bike page 80 standard sprocket size engine 15 rear wheel 41. thought I wasn't going to crazy adding a couple to the back .Even at speed got a real on of feel . wont do 200 wurst luck.
Your little book cannot be for the 650R...my little book states 14 front and 48 rear as standard sizes
Re: tech question
Stock gearing in the USA is 14/48. I can hit 104 on pavement with the throttle pinned. Though if I were to ride, 50/50 road/tight dirt, I might switch to a 14/46
14/48=3.428
14/46=3.285
3.428-3.285=.143
This would be a 14.3% change in rpm for the engine rpm at speed.
The book states 14/48 for ED, DK types and 15/41 for U type. U type is strictly road riding...no dirt.
If you buy new sprockets, get Ironman sprocket out of Minden, NV. They are as light as aluminum but last 5 time longer.
14/48=3.428
14/46=3.285
3.428-3.285=.143
Re: tech question
I will give the ironman sprockets ago next time.Got any suggestions for linkage & shock bearings thought all balls look ok. Found U code in my owners manual just has Australia next to it mustn't have thought there was dirt hear when they printed.lol
» temperture guage set up
» Tech Help XR 650 R
» Vapour Tech Help
» vapour trail tech speedo
» vapour tech problem
» Vapour Tech Help
