Harbor Freight Digital Ultrasonic Cleaner
So I bought this thing because I took my carb to a buddies house the first time I was taking it apart and we used his. My carb had gunk all over and was generally dirty from being used. This ultrasonic gizzmo cleaned my carb to the point where it looked fresh out of a hot tank, inside and out. I was very impressed.
http://www.harborfreight.com/25-liter-ultrasonic-cleaner-95563.html
I've used a couple different cleaners. The ultrasonic powder harbor freight sells for their ultrasonic cleaners; which I promptly threw into the trash, what a bunch of garbage. Some stuff called "super clean" from autozone was pretty aggressive and depending on the aluminum would tarnish it. So off I went back to harbor freight and bought a gallon of this business they use in their regular parts washers for only $9.99. I run a 50/50 mix with water and it cleans fantastically. Straight out of the jug is pretty concentrated stuff. I really recommend diluting it some.
Since I've used it on all kinds of things. Most useful to me has been on fasteners but greasy nuts, bolts, washers, brackets, spacers, sprockets, clutch and brake perches, cleaning up my tools, my carburetor components, suspension compnents and even a whole chain. Yes, the whole chain
So I thought I'd share a couple before and afters. I actually struggled to find things that needed cleaning, but I did find a couple things. These parts were never prep'd or polished after coming out of the cleaner. They went straight in, ran a cycle then brought out and dried off. Thats it. No scrubbing, no brushing, no scraping, no wiping down with a rag at all.
WHEEL SPACERS
UPPER TRIPLE BEARING
UPPER TRIPLE CLAMP
LOL, I thought it would fit. Guess not
Cheers! Now go clean some stuff
MA$TER_E
WHEEL SPACERS
UPPER TRIPLE CLAMP
MA$TER_E
Re: Harbor Freight Digital Ultrasonic Cleaner
They are good , i have one at work and use it to clean my parts btw master i have seen pictures of you carb , it was spottless but i take it as you are one of those OCD sufferers
Hello. My name is Eric and I'm addicted to clean motorcycle parts.Mad Frosty wrote:They are good , i have one at work and use it to clean my parts btw master i have seen pictures of you carb , it was spottless but i take it as you are one of those OCD sufferers
MA$TER_E wrote:Hello. My name is Eric and I'm addicted to clean motorcycle parts.Mad Frosty wrote:They are good , i have one at work and use it to clean my parts btw master i have seen pictures of you carb , it was spottless but i take it as you are one of those OCD sufferers
Ahh my young apprentice....that carb is Eric's not mine lol.
Happy New year guys....
I FOUND IT! I wanted to reply to that with one of my favorite cartoons but couldn't find it. Well, I found it
I have one at work also but you know what works better for carb jets - coke (as the drink ) - for real, try it!
» Rear tire wear limit?
» New Plated BRP in Central California
» Ecessive oil leaking from air cleaner drain above chain ????
