oil sight tube
oil sight tube
hi all,
ok this really bugging me - someone on here made an oil sight tube using banjo fittings but I can't find who - help!!!
cheers
cheers
Re: oil sight tube
Banjo's is the way to go anything is better than the ugly compression fittings....
http://www.honda-xr650r.com/category/common-part-tips-and-ideas/
Re: oil sight tube
Yeah I know its ugly and that's why I want to avoid it...plus you have to have that huge loop going rearward first. I actually have all the bits to make one with the compression fittings but hate the look of it. The other version I have seen uses stubbier brass fittings but I don't want to use brass. So.......
Re: oil sight tube
SkidMark wrote:come on put me out my misery...need some advice about it!
Sorry Mark forgot to look, I think a nice clear solid tube running between 2 stainless banjo bolts would be a lot better, not sure what to use why not drill a series of holes up the frame and put glass grub screws in ?....that way you can see the oil level and won't have any nasty tubes on the outside !!!
