cfr 450 plastics fit on a xr650r?
Has anyone put cfr 450 plastics on the brp. Will the crf460 rims fit on the pig also?.thanks
Re: cfr 450 plastics fit on a xr650r?
CRF wheels will fit the XR. You will need spacers to adapt the small xr axles to the big CRF bearings. This place has exactly what you you need, he is very helpful and knowledgeable regarding wheels. I think the spacers were $35 a set.
http://www.motoxindustries.com/
Did you have to cut the 650 inner fender to keep the stock air box and rear mud flap?
Yep ...and you find some info about the fender swap here:
http://supermotojunkie.com/showthread.php?130132-Clean-White-XR650r-SM-lots-of-tricky-bits
http://www.xr-italia.com/forumxr/index.php?topic=34471.0
You have to work and cut very carefully to have a good/tasteful result. I have done it 15 to 20 times and still every time it's precision work.
» After Market Plastics
» What does the XR650R need?
» RIP 04 XR650R
» RIP 04 XR650R
