K&N filter?? Running rich??
I know all the arguments about using K&N off road, but that isn't what this post is about.
Just sharing this to help anyone cleaning and re-oiling their K&N air filter......
I've cleaned and serviced the bike including a carb clean and refurb. It then began running rich.
After fiddling around with the jetting I thought about the air filter again.
When i cleaned it I used the recharge kit with the cleaner and squeezy bottle of oil. I followed the directions but they don't tell you how much oii to use. I squeezed what I thought was a SMALL amount on each pleat on each side. The filter turned that lovely red colour I thought all was ok.
However this turned out to be way too much oil.
I later checked out their website which says the filter only needs 17ml of oil.
This seemed a ridiculously small amount but I thought I'd give it a go. I cleaned the filter again, and this time used a syringe to measure out the oil and applied it to the pleats on the dirty side only.
It didn't look like it was nearly enough, but leave it to sit for a little while and it does wick throughout the whole filter.
So if you've got a K&N and you're running rich, before you play about with the carb, have a think about the filter!
Re: K&N filter?? Running rich??
I run BMC filters on my ZX12-R...similar to K&N and I use the spray oil; after cleaning the filters you just spray it over the surface and job done ?....thanks for posting as I am sure it will help out others....
» My bike is running super rich. Can anyone help me please?
» Advise on carb setup. Running rich I think
» Rough running, advice please
» No foam filter
» Rich or Lean?
» No foam filter
» Rich or Lean?
