Clutch/Decompressor Bolt
Anyone ever swapped the above bolt for 1 without the fixing hole/thread for the stock hand guards ?....it's a double shoulder bolt and the CRF version don't fit as they are single shoulder ?
Re: Clutch/Decompressor Bolt
Not sure what you are after , but this might help .
http://www.honda-xr650r.com/category/common-part-tips-and-ideas/
Hmmm not sure how their mod works as 90114-428-870 is a normal shoulder bolt, where as mine has 2 sizes a larger diameter for the de-compressor lever followed by a smaller diameter shoulder for the clutch then topped off with a M6 nut....
Got a picture on my phone will pop it up tomorrow
» Head Bolt Pattern Measurements & Clutch Plate Thickness
» Auto decompressor
» Decompressor system check
» Swing Arm Pivot Bolt Stuck
» bolt sizes - help please!
» Auto decompressor
