oil leak
oil leak Empty oil leak
Post  Guest Tue Jul 01, 2014 5:12 pm
Hello forum members, I'm new to the forum/xr650r world. Got a chance to own a 2001 xr650r and am concerned about a little oil leak from the bolt/nut directly across from the rear brake lever. I'm a complete novice when it comes to trouble shooting and maintenance, so please bear with my ignorance......
Bike started great, oil is at right level. Rode the bike for a mile and noticed a bead of oil on said part. Wiped off oil an tried again.......same result. Any ideas and or how deep a problem this might be?
Thanks for any ideas.
oil leak Empty Re: oil leak
Post  Mauser Tue Jul 01, 2014 9:19 pm
Just the gasket needing replacement...small job and cheap....do it next time your chaning the oil.
Welcome to the forums.....post a picture of your new bike  listen up
CLUTCH COVER
11352-MBN-671
£6.18
Item 5
http://parts.hondaofbournemouth.co.uk/products/2002-698/right-crankcase-cover-17443.aspx
Post  Guest Wed Jul 02, 2014 4:32 am
Great, thanks for the kind welcome and guidance!
Post  Guest Fri Jul 04, 2014 8:23 pm
Welcome on board  cheers
Post  Guest Fri Jul 04, 2014 8:33 pm
how do i put a darn pic on this reply.............computers are dumb,not people!
Post  Mauser Fri Jul 04, 2014 8:37 pm
Copied from my other reply...
Right click on your picture on photobucket and select properties at the bottom...highlight and copy the long url on the picture....looks like this https://2img.net/h/i1295.photobucket.com/albums/b640/offroadjeep_yj/Mobile%20Uploads/image_zpscf9dd3d5.jpg come back to here and then insert the picture into your post by clicking the little icon 18 from the left hover your mouse over it says "Insert an image" paste the long url into the top box and click "insert" it should add tags around the url like
Then your all done... dead easy once you have done a few
Post  Guest Fri Jul 04, 2014 8:38 pm
oil leak Dsc06510
Just like this  BRP smile
Post  Guest Fri Jul 04, 2014 8:42 pm
Image hosted by servimg.com
??? this worked, ha!
sorry pic is 90 degrees off, oil is beading up at this nut.
Post  Guest Fri Jul 04, 2014 8:46 pm
Here it is when I picked it up.
Post  Guest Fri Jul 04, 2014 8:49 pm
Thanks for the tutorial Mauser banana
Post  Guest Fri Jul 04, 2014 9:19 pm
hakai777 wrote:how do i put a darn pic on this reply.............computers are dumb,not people!
 2 thumbs Mauser had to help me out today too. Glad I'm not the only one!
Post  Guest Fri Jul 04, 2014 11:48 pm
Hello Mauser,
Just to be sure.........the nut in the picture I posted is the same one you were responding to(meaning, easy fix with new gasket)? Thanks so much for your time!
Post  Mauser Sat Jul 05, 2014 9:36 am
Yup new gasket needed....comes of easy, here's what it looks like below...pulled mine off some time back to check & clean the lower mesh screen...add some copperslip to the seal faces that way it will come off again without ripping the gasket.... listen up
oil leak DSC02024
Post  Guest Sat Jul 05, 2014 4:59 pm
Awesome! Thanks so much!!
Post  Mauser Sat Jul 05, 2014 6:51 pm
Your bike won't have the attached tap wrench like mine does....mines special you see  Bump
