Fuel leak
Fuel leak
Now come on guys I never ask for your help....so today had a blast on my bike and just before getting home I did a small wheelie over a speed bump....300mm max pulled onto my drive and she cut out and then dropped some fuel on the drive from the over flow pipe ?.....any idea's ? sticking float maybe.
Re: Fuel leak
Your bike is not used to do them wheelies so it might just needs to get used to it .
Too much fuel went in the bowl that could be incorrect float adjustment or sticking float valve ( you should replace that now and again as they wear / get pitted ) .
Re: Fuel leak
OK will drop the bottom of the bowl at some time and check the seat, funny how it only leaked after the wheelie ?....hasn't leaked prior to this event ?
Re: Fuel leak
My guess would be the float level is too high, bend the tang a bit while you have the bowl off.
Re: Fuel leak
I have a friend that wheelies his 650 all over the place with the front about 4’ off the ground, every time he sets it back down fuel comes out the over flow but it has never died. Now we are going between 30-50mph when he is doing it but it doesn’t act like it wasn’t to die out.
Re: Fuel leak
To be fair I did virtually stop as soon as the front wheel came down....15 yards maybe rolled down my drive and she cut out I guess if I had carried on riding her she would have been fine .
Re: Fuel leak
My friend who was slightly behind me said it was pretty spectacular, it felt pretty cool
Re: Fuel leak
Bikes starting cutting out again, cannot be fuel as she starts back up no problem, plug looks very rich...
So would I be right in thinking to lean her out with the air mixture screw 1/4 turn ?.....
Re: Fuel leak
That's a brand new plug as well only done about 20 miles
Re: Fuel leak
What size main is in it?
Have you over oiled the air cleaner or is it really dirty?
I would be more inclined to lower the needle one clip position, that would make more of a difference than leaning the idle mixture.
Again, I would lower the fuel height in the bowl as this could be a contributor to the issue also.
Re: Fuel leak
what's your carb set up? I would try what zoro said move needle clip down, actually I think move clip up one notch will allow the needle to sit lower leaning it out I think? start with new plug and take piggy for a run and then do a plug reading.
Re: Fuel leak
Stock jets... 68s and whatever the stock main jet is oil filter not over oiled and clean, I do potter about on my baby not exceeding 40 very often mostly 25-30 in 5th, she is low geared however 13~50 which does pull the rev's up....
Will try the clip position as it's an easy and cheap option lol
Re: Fuel leak
A WHEELIE?
Impossible!
I have it on very good reliable account from a mod here that our bikes canNOT wheelie.... period!
That's gospel bru, face it.
So, must have been imagination...
Stop smoking those green ciggies please Mauser?
Next you'll ride into a blue Elephant, or a midget Martian!
Except from your body, wife, kids and immediate collective family also this forum will be thankful for that!
A wheelie.... now I've hear dit all!
You realize how your bike must feel now?
The poor thing, from happy toddling around to being thrashed over speedhumps - can't get any worse now innit?
Mind, that sudden jerk may have dislocated a minute spec of, dare I say it, d i r t inside the tank, and subsequently this may have found its way through the tap into the fuel line... where it had to face the carb with all its funny parts, and caused havoc by unseating the needle's seat!
Dunno about you Maus' but I'd clean it, pronto!
PSst: maybe mount an inline fuelfilter then too? Such would allow you to wheelie more, lord forbid make it a habit even, oh hell, mono the streets if not lanes! Your local copper will like you for such even, as that will give him a real victim to hunt, he's fed up already chasing old grannies who lost their umbrellas!
Impossible!
Re: Fuel leak
Is that 40mph or 40kph??
Yep, lower the needle/ raise the clip.
Check the sizing on the main while you're in there too.
My plug looked like that with a 175, progressively worked my way down to 165 which cleaned it right up.
2.5 turns on idle mix and I have plugged the vacuum port on the fuel cut off diaphragm which stops it from working whilst eliminating any chance of a vacuum leak also. Fixed my idle issues up.
Found it surged with the 175 too.
Re: Fuel leak
Update I pulled the carb today and the clip was on the 4th position from the top ? I uncorked my carb years ago and would have thought stock would be middle position ?.....I have moved it up 1 now it's in middle position will see how she wheelies
Re: Fuel leak
Not really had chance to try her out, I did find the carb top gasket had expanded to such a state it would no longer fit....I needed to cut out 4mm and super glue to ends before it would fit...
The I panicked yesterday as I thought the plastic washer had fallen out as I failed to spot it when I took the carb to pieces...pulled top again and there it was in the right spot.....phew
