Decompressor system check
Bike: XR650R, 2001, 15000km
Syntoms:
-Sometimes no compression when kick starting. Sometimes looses power at high speed, sometimes not good response at high speeds <= engine sounded great and usually fast response, no other syntoms.
-Last time I came home whith quite high speed engine really suddenly died few times but was running and started to keep this clacking soud. Like metal to metal.
Checking:
- Next day it was hard to start and to find compression and backfired. When started it was ideling just fine but had this terrible clacking sound.
-I checked the valve clearance when cold and those were in specs + Rocker arms were loose at TDC.
-I noticed that just before TDC there was that click on each round I turned just before TDC
-when I removed the cylinder head cover there wasnt that clicking soun anymore <=was it decompressor system then which made the proplems and sound ?
-when I played with mechanics everything looks to be in great shape but that DECOMPRESSOR CAM looks a kind of loose and phlegmatic It does not feel food and some scrathing noice can be found also.
I am going to disassembly the decompressor system and check whats wrong but I would be grateful if someone would tell me how it shoud feel like ?
-markku
Syntoms:
Checking:
-markku
Re: Decompressor system check
Welcome the de-compressors don't normally cause any problems ?...sorry cannot help with it's function....
Disconnet the decomp-cable and mmake sure the lever on the head seats at 'not active'.
Adjust the valves without turning back the crank a single millimeter!
Recheck the valveplay.
Go ride - still same?
Then take valve/rocker cover off, and see what's wrong.
» Auto decompressor
» Clutch/Decompressor Bolt
» In need of a Exhaust system !
» Akrapovic complete exhaust system.
» Rekluse system
» Rekluse system
