To float or not to float ...
Hi,
Disclaimer; I posted a similar question over in advrider ...
So, can anyone enlighten me as to the pros/cons of isolating DC ground vs. tying such to the frame? And which would be best for a XRR running just a DC fan, and a Trailtech Vapor ...
TIA,
Ace
TIA,
Ace
Re: To float or not to float ...
Your word 'float(ing)' is incorrect here, pedantic-me here
You run AC AND DC both?
If so keep the DC-minus as cables & insulated from the ground=frame.
If full DC only then use the frame=ground=DC-minus - and no, this will not interfere with the ignition as this is an entirely separate system (also using the ground=frame but don't worry about that).
Clearer now?
Oh, in te almost-impossible unlikely case that you have the one stator (a rare Electrosport thing I think) which has a T junction connected to the frame then you're forked (unless you clearly know what you're doing but your question indicates otherwise, pls no offense), best is then to get another stator first.
Clearer now?
Hey, thanx for the response. Be as pedantic as you like, I'm good with it . So, leaving the ignition sys. out of the equation, I'm running DC only. In my case then, you're advising I use frame=gnd=DC-minus.
I have a dual 100W output stator, and am only going to use a single 100W output for an up-coming trail ride. This stator has no T junction. And no offense taken, I know just enough to be dangerous to myself .
Thx,
Ace
Thx,
Ace
Carlo & Gustav
Yip, for full-DC use the frame, however use a wire still for those users which are not grounded (taillight, it's on plactics) or are "grounded" through bearings only (anything on your headstock!).
And a good idea too to use only one 100W winding, 200 is a bit of an overkill.... and besides, your RectReg (RR) will cope better: choose a 150W unit? Keeps cooler that way, better too big as 'proven to be just not enough after a while'
Have fun bru!
Oh, that 2nd 100W winding, you will insulate it right?
You must in fact, insulate both ends!
Have fun bru!
Yep, insulating all unused wiring is generally a . I'll use the 2nd 100W output when I put her back in street mode, for lighting (all LED) primarily. I have a 2nd reg/rect. for that output. And I'll fuse ea. leg of course, 10A ea. seems to be acceptable from what I've seen here, and ADV, and TT ... guess I could do the actual load calculation and fuse accordingly though .
Thx,
Ace
Thx,
Ace
» Tech Help XR 650 R
» XR650R Help, countershaft end float
» Float level check
» Float height question
» carburator float valve sticking
» Float level check
