Is anyone running an oil cooler?
If so a post on this mod would be nice.
Re: Is anyone running an oil cooler?
I asked this question on ADV.
More oil capacity would be fantastic, i dont commute on the bike so i dont have to change the oil so often. Despise it!
I don't worry about my oil temp too much being a liquid cooled engine and aluminum frame. The dipstick temp gauge is a nice addition tho.
Impressive. How much extra oil does it hold?
Do you extend your intervals now?
True dat and those USD's are sweet too. That R has set the bar i'm thinkin..
How To...How To...How To...How To...How To...How To...How To...How To...How To...How To...How To...How To...
Afternoon all, Just cut the return line and mount it in front of the radiator and put some protection on it and add a bit more oil and thats it. here a link to have a look at http://www.ec21.com/ec-market/oil_cooler.html This is almost the same as mine http://pitbike.en.ec21.com/Taiwan_Oil_Cooler--849012_2663343.html Or even this one http://dannyjames.en.ec21.com/Taiwan_Big_Oil_Cooler--792699_2864918.html
Great job. Where did you mount the thermo switch into the cooling system?
thanks,
Hodakaguy
thanks,
Hodakaguy
Afternoon all, the temp control is a appliance over temp self resetting cutout ( 88-90 c ) mounted next to the overflow pipe with some epoxy it's been there for about a year and hasn't moved at all. The only problem is it's a normally closed contact so i had to run a relay to change the switching it works great here is some pic's
» Running at last
» 2005 impossiable to start when hot
» Anybody running warp 9 17's ?
» Running Temperature, how hot is too hot?
