12 V Power
12 V Power
Hey Guys, Just wondering if anyone knows if and where i can Pick up 12 Volt power on the XR-R to power a Trailteck dash, i powered it up to the head light at the Globe to experiment, but it says its putting in 18 to 22 volts, bit weird any clues appreciated cheers guys
Chrimsey
Chrimsey
Re: 12 V Power
No 12V on the bike, just "regulated" AC - which will swing quite a bit if you rev the engine.
But why? The Trailtech takes any supply, from DC to AC, from 4 to 400 Volts - and that is what you are feeding it? Should work...
Re: 12 V Power
Cheers i was just checking, as you said i swings pretty wildly when revved, i just was not sure it this would damage trailtech, cheers fot the info BURP!!!!!!!!!
» How much power is left?
» SEE TO MUCH POWER
» Power for USB and vapor dash
» trailtech vapour power
» 2005 xr650r titled
» SEE TO MUCH POWER
