How much power is left?
How much power is left? Empty How much power is left?
Post  Guest Thu Dec 18, 2008 7:02 am
I bought my bike used and all I know is it has a Baja Designs set up. PO said it has the 200 watt stator upgrade. Anyone know what power is left over? IF any? Anyone running anything extra off this system.
Thanks!
How much power is left? Empty Re: How much power is left?
Post  Guest Fri Dec 19, 2008 5:13 am
ooweel wrote:I bought my bike used and all I know is it has a Baja Designs set up. PO said it has the 200 watt stator upgrade. Anyone know what power is left over? IF any? Anyone running anything extra off this system.
I have a Moose 200 watt stator, (Parts Unlimited from Electrosport) don't know if it's the same. On mine there are two extra 100 watt legs free for powering whatever you desire. Each leg needs its own regulator/rectifier in the circuit wired parallel to ground. Depending on what farkles you already have perhaps one or both are still free?
dougc
Post  Guest Fri Dec 19, 2008 11:12 pm
I'm getting ready to install a Ricky Stator - 200W. I'm going to run one 100 watt leg directly into a AC regulator and then to the light, run a 90W bulb or so. I'll run the second 100W leg into the Baja Designs reg/rectifier and then into the normal power sys. Should have power to spare on that circuit with 100W supplying it. I'm going to power my GPS and maybe a small power port so I can charge my cell ect. on the road.
Hodakaguy
How much power is left? Empty Power
Post  Guest Sat Dec 20, 2008 3:11 am
That's all I want to do. Just add a power source for a GPS and my XM radio or be able to charge my cell.
How much power is left? Empty Blinker power source for charging GPS?
Post  Guest Mon Jan 12, 2009 11:23 pm
Has anyone out there utilised the indicator power source to charge GPS units etc?
Here in OZ BRP's are supplied with 12v / 21W indicators
Two x 21 watt bulbs per side equates to approx 3.5Amps @ 12 volts.
I imagine this is a ready power source independant of other standard electrical appliances ie head/tail/brake lights.
Has anyone checked if the indicator power source is regulated. if so it may be very handy for 'appliance charging'.
Post  Guest Tue Jan 13, 2009 8:19 am
Afternoon All, I installed a ricky stater 200w (2x100w outputs) after testing various connections i found using a single ouput to run the high watt head light i lost to much voltage at low revs (the100w rated is at 5000rpm i tested). so the best performance was to paraell the outputs and run a single 200w and convert the whole bike to dc. I used a ac regulator and a 40 amp rectifier  and a big filter capacitor( you loose about 1< 1-1/2 volts at full load ) and installed 6 batteries and changed indicators,stop/tail lights to led globes ( big power saving ) and every thing works well. I also have a gps and a acewell tacho/speedo/temp gauge,2x35w HID spot lights and a35w HID headlight all running together no probs.And with the batteries you can use indicators,leave your parking lights on charge cell phone ect.without the bike running. I can even run the headlight for about 5 min before the batteries run down hers a pic any questions please ask.How much power is left? Imgp0217
Post  Guest Tue Jan 13, 2009 8:56 am
Wow the dudes got three ways to obtain SOG!
How much power is left? Empty Sweet speedo!
Post  Guest Wed Feb 18, 2009 12:05 am
... love the analog speedo unit, where'd you get it?
Post  Guest Wed Feb 18, 2009 5:48 am
It's the stock unit on Australian models
Post  Guest Sat Aug 28, 2010 12:26 am
Please refer to this thread:
http://www.xr650rforum.com/xrr-main-discussion-f1/xrr-hid-headlight-t1060.htm#6102
this works with the street legal model that was released in Australia between 2004 - 08
