Valve Spec Help
Valve Spec Help
Hey guys, Damian here. I do not own a xr but could really use your help. I am in the middle of a full build on a 08 Honda 700xx. I have my head ported with other bolt ons. I was going to have Kibblewhite make me some custom 37mm intake valves till someone brung to my attention the xr already has this... Could anyone get me the overall valve length and stem size please? Any help would be greatly appreciated.
Re: Valve Spec Help
Having trouble posting pic's anyway the valves are slightly different lengths but the stems seem the same.
Re: Valve Spec Help
Fixed the post for you. Remember to use the image icon then paste the image link in the box...Or insert after.Pikkos wrote:Having trouble posting pic's anyway the valves are slightly different lengths but the stems seem the same.
Re: Valve Spec Help
Did the XR have dual valve springs or a kit for them? I am looking to get some XR chromoly or titanium retainers, The 700xx has dual Valve springs and i'm sure there would be a difference...
Re: Valve Spec Help
Good morning Smo0oth 1, I got the valve spring kit it,s got light weight dual springs + titanium retainers, I will take some pic,s when i get home from work
Re: Valve Spec Help
I really appreciate the help, this thead will be helping us XX owners allot. If possible measure the overall height and bottom spring diameter as you did in the valve pics. I want to ensure they sit on the head correctly. Thanks for your time.
Re: Valve Spec Help
Back again, still having trouble posting pic,s so have a look https://s302.photobucket.com/albums/nn107/Pikkos21/
Re: Valve Spec Help
Well there is a slight difference in the valve springs so were not going to chance anything. The XR 102mm piston is a match except for the 23mm Wrist pin, the XX is 24mm. We had a XR Stage II HotCam we compared with the XX and its a perfect match. The XR cam does not have the Decomp but the one off the XX cam will fit it.
I appreciate your time and patience, your help has really sped up this build.
Re: Valve Spec Help
Sorry about all the questions but search isn't helping much. How much low end will you lose with a HotCams stage II cam over a stage I? I am building with wood trails in mind and do not want to sacrifice much low end torque.
» Abiqui to Ojo Exploration Ride
» Valve adjustment Q's
» Doing my own valve adjustment
» valve question
» valve question
