disregard thread.
disregard thread. Empty disregard thread.
Post  Guest Mon Apr 01, 2013 5:22 am
Disregard this post. Leaving for thumper talk.
Last edited by cambeck510 on Mon Apr 01, 2013 4:00 pm; edited 1 time in total (Reason for editing : Leaving forum with advice to go to thumpertalk.)
disregard thread. Empty Re: disregard thread.
Post  Mauser Mon Apr 01, 2013 9:24 am
Sorry to sound rude but you have brought an "L" model 650.....this is the 650R model forum.
The 2 bikes are light years apart, totally different frame and engine, about the only part which might be the same is the front wheel Bump
650R....
disregard thread. 2006-Honda-XR650R
650L
disregard thread. Honda-XR650L-picture-1
You would be better off trying Thumpertalk for help with your bike BRP smile ....google it.
Post  Guest Mon Apr 01, 2013 3:33 pm
cambeck510 wrote:I bought a 1995 XR650L with 20k miles for 800, it starts runs and drives. Motor is crisp sounding with throttle blurp and has really good power. The reason for the lower price is that it has an engine noise. At idle it has a rattle in the motor. Off idle it goes away. I took the valve cover off with motor still in bike so I only had limited room to inspect, but I have checked that the oil is pumping into the valves, the valve adustments are ok and it appears that the rocker arms are smooth and the timing chain tensioner is good. Any experience with these types of sounds?
So from here I am planning on tearing it down and rebuilding. Crank bearing, rod / rod bearings, piston kit, hone or bore, timing chain, clean and polish head, valve seals / springs / valves and reasemble.
Where do you suggest getting parts for the best price?
Thanks for any help.
Cameron
If the noise goes away when the engine is revved I don't think it is anything serious.
Using a long screwdriver put the blade against various parts of the engine and the handle against your ear you should be able to pin point the area where the noise is coming from.
The clutch makes a rattling noise on many bikes and that tends to go away when you pull the clutch lever in or rev the bike.
The type of engine rebuild you are looking at would be very expensive and if there is nothing wrong then a waste as well.
If it was my bike and the noise went as I revved it I would just ride it. If the noise increased with revs I would stop until I had established the cause.
Good luck and keep your eye out for a XRR they are a bit special. Wink
Post  Guest Mon Apr 01, 2013 5:26 pm
Oh not again , Mauser can you stop scaring the new members away please ?
razz
Post  Mauser Mon Apr 01, 2013 6:32 pm
Only pointing out the obvious ?...OK maybe I should have said drain and remove the radiators then remove the head Bump
Admin ban me asking for it for stating the facts of life to a new member Frustrated
Post  Guest Mon Apr 01, 2013 11:21 pm
LMAO! waiting
Thought I'd pop in and say welcome. Well... Welcome lol!
Post  Guest Tue Apr 02, 2013 2:01 am
banana NEW RECORD!!! LESS THAN 1 1/2 HOURS!!!!! thats funny
Post  Mauser Tue Apr 02, 2013 9:06 am
chrislogan27 wrote: banana NEW RECORD!!! LESS THAN 1 1/2 HOURS!!!!! thats funny
You sure I thought we had 1 less than that Bananatool ....note to myself "must do better" Bump
Post  Guest Tue Apr 02, 2013 10:35 am
Well now, I just bought a Garelli Junior Cross 50 thumper, and it also has a funny sound when it runs. It goes something like "ringdinggdinggring.." and it smokes a lot.
Anybody know what I should do?
Cam510, you should check the camchain tensioner, at 20Kmi this is probably what is bothering you.
Now, back to that Garelli....
Post  Guest Tue Apr 02, 2013 11:34 am
Burp, maybe try the baned cr site! listen up
Post  Guest Tue Apr 02, 2013 12:00 pm
"RINGGEDINGGGEDINGGGGG...."
As someone said, I lurve the smell of 2stroke in the morning BRP smile
You're a night-owl Chris, or an awfully early bird. CR's banned? Hey, throw me a in-good-nick 500 please, I'll nurse it up sandy dunes I'll promise.
Well, probably not real nursing razz
Post  Guest Wed Apr 03, 2013 2:26 am
Early bird! I start realy early, I get 12 hours to haul crude oil, the earlyer I start, the sooner I get to go home! banana
