H6M Headlight Bulb
Page 2 of 2 Previous  1, 2
H6M Headlight Bulb - Page 2 Empty Re: H6M Headlight Bulb
Post  Mauser Fri Feb 20, 2015 4:35 pm
Not all down to cost, "if" there was a LED bulb which would fit into my stock headlight WITHOUT altering anything I would buy 1.....but there isn't lol....hence my new method sorts all my problems out in 1 go....I can get 10 bulbs for less than £2 delivered....bargain razz
Post  Guest Sun Jul 26, 2015 7:25 pm
Mauser wrote:Not all down to cost, "if" there was a LED bulb which would fit into my stock headlight WITHOUT altering anything I would buy 1.....but there isn't lol....hence my new method sorts all my problems out in 1 go....I can get 10 bulbs for less than £2 delivered....bargain razz
There is an LED that fits straight in that fitting - See my Headlight thread
Post  Mauser Sun Jul 26, 2015 10:10 pm
Now bear in mind mines a US spec bike.....single filament dipped beam headlight Smile....
See my bulb topic or look at pictures below....
H6M Headlight Bulb - Page 2 DSC06567
H6M Headlight Bulb - Page 2 DSC06568
Post  Guest Mon Jul 27, 2015 6:05 am
Mauser - I think mine is also stock as single filament but someone has fitted a dual filament wiring harness (plug) on the back of the headlight
Post  Mauser Mon Jul 27, 2015 9:01 am
So you don't have a single filament bulb Smile.....I like my simple stock bike listen up
Post  Guest Wed Aug 05, 2015 7:30 pm
The fitting is a P15D-25-1 which is identical to H6M - The H6M is a 35/35 halogen and is marginally brighter than the 30/30 P15D-25-1
H6M is only available from the Honda stealership at around $30.00. Tusk does one but the local distributors don't import it to SA
