Head Gasket Thickness
Could any of you guys let me know the Head gasket thickness on these bikes. I've tried searching the site with no luck
Re: Head Gasket Thickness
Here is the part number...Maybe you can call your local shop and see if they have more specs?smo0oth1 wrote:Could any of you guys let me know the Head gasket thickness on these bikes. I've tried searching the site with no luck
# - 202362-001
Thanks for the info but I've called XR's only and a few other Honda "specialist" with no luck. I'll just have to wait till mine comes in Wed. If anyone knows before then it would help allot
Morning smo0oth 1, Just measured my used one it's 0.56 mm thick, I'ave a new one in the shed if you want the thickness i can mearure if you like
» Head Bolt Pattern Measurements & Clutch Plate Thickness
» head gasket leak
» Right Crank Case Gasket
» XR 650 R: rubbber gasket for airbox
» Does XR650R use rocker cover gasket?
» head gasket leak
