head gasket leak
head gasket leak
Hey guys,
My head gasket leaks and I want to replace it. I am fairly good with 2stroke engines but I've never dig a 4stroke one deeper than the carb. Please give me some insights. Would I have to time the engine afterwards? Adjust the valve's clearance? Is there something else that I haven't thought of?
Any tips would be greatly appreciated.
Thank you for your time,
George.
George.
Re: head gasket leak
Yes and yes.
The cam's overhead so you need to disconnect the camchain - which is easy because you'll take off the cam's sprocket.After reassembly you need to set the timing (markers on flywheel=cranck & cam) correct, and of course you need to set the valve clearance - which is routine maintenance anyway.
Download yourself the Workshop Manual!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You MUST have this, pictures & all, it explains all in proper detail.
It would be the perfect time to upgrade your cam chain an tensioner with HRC parts.
Those parts are hen's teeth Aurora, can't be gotten hold of as far as I know - or do you?
Hey,
Thank you all very much for your answers. HRC parts would be great but more expensive I guess and I thing they change the power chart of the bike (loosing some low end in favor of high etc) am I wrong? For the time being I saw in the manual (got one! that I am going to have to change other gaskets too like the the valves cover ones and so on.. So, price wise, do you suggest buying a top end gasket kit or one by one the ones i need?
Thanks again,
George.
Thanks again,
George.
BuRP wrote:Those parts are hen's teeth Aurora, can't be gotten hold of as far as I know - or do you?
Parts available...kit not available.
You would have to piece one together.
HDLParts.com
CHAIN, CAM (14401-NLB-003 ) $120.98 $90.49
TENSIONER, CAM CHAIN (14511-NLB-000 ) $145.16 $108.58
Does this help
Honda HRC Power Up Kit PN#: 06130-NLB-010
HRC part numbers in this kit...
13011-MBN-305 Rings. Note: confirm proper rings for piston size
14520-NLB-003 Tensioner
13101-NLB-000 Piston
90088-MK4-600 bolt
99101-357-188 Main jet
99101-357-185 Main jet
99101-357-182 Main jet
99101-357-180 Main jet
99101-357-190 Main jet
16012-MBN-641 needle and seat
90041-NLB-000 rubber.........need two
31929-NLB-003 sparkPlug
31920-NLB-003 sparkplug
90602-MBN-670 circlip....need two
14620-NLB-003 Guide
14511-NLB-000 Guide
14560-KCW-851 gasket
12191-MBN-670 gasket
12251-MBN-670 gasket
22401-NLB-000 springs
13111-MBN-670 wristpin
14321-NLB-000 gear
14312-NLB-000 gear
14000-NLB-000 cam
14401-NLB-003chain
11394-NLB-670 side cover
061994-NLB-010 kit
00X32-NLB-000 manual
Thanks Aurora,
and I'll print these numbers for archiving.
As I've got the camshaft (a genuine HRC) and a h/c Ross piston already I'll only need that chain.
Mind though, no sprockets listed, but I thought this was a type of morse-chain, which would not run on the std sprockets?
BuRP wrote:Thanks Aurora,
Uses different sprockets.
Timing sprocket: 14312-NLB-000
Cam sprocket: 14321-NLB-000
Here is a link for the HRC manual
http://lalala.chu.jp/finedirt/dl/XR650RPowerupKitManual.pdf
re: camchain
ive built a few of these mtrs, never had the camchain even look slightly worn, even with running hi lift aggressive ramped cams &race valve springs, i replace the camchain at each rebuild[ naturally], save your money , the cam setup with ball bearings dont seem to cause any excessive wear on the chain, the std chain/ sprockets are more than up to it
» Oil Filter Cover Gasket Leak
» Head Gasket Thickness
» XR 650 R: rubbber gasket for airbox
» valve question
» oil leak
» valve question
» oil leak
