front fender replacement
I want to put something different on my BRP. The stocker is goofy looking. Anyone have anything better?
Re: front fender replacement
xr400 bolts right up and looks decent enough (i think), can find in white or black too, which is good and they are cheap about 25bucks.
http://www.xrsonly.com/content/index.php?page=shop.product_details&flypage=shop.flypage&product_id=734&category_id=8&option=com_virtuemart&Itemid=89
XRsOnly has a Supermotard fender that might suit your taste.
I use to own a DR650 and I was able to trim the front fender right about an inch or so from the clamp. I then reversed how it was mounted so basically it was mounted with the rear of the fender going forward.
It worked pretty decent...The old fender was all scratched up and looked like crap to start with. After I did the trim on it and mounted it back up I didn't even bother ordering a new replacement. Haven't checked to see if this will work on the XR but it should. Most issues will reversing the front fender is clearance with the frame but you can trim it as short as you need. If you're going to do some serious off-road riding on your XR, I wouldn't go with this mod since there is no back side fender...for motar/street it's a lot cheaper then buying a new fender...Go buy yourself a new dirt fender, cut the old one for the street and just switch back and forth as you need.
» CRF 450 front fender for XR 650 R
» Stock headlight replacement
» HID without Stator Replacement
» Crf rear fender
» Clutch plate replacement
» Crf rear fender
