Rough running, advice please
My 2005 is running rough once it's been going form about 1/2 hour.
Wont idle and is backfiring.
Any advice appreciated.
dave
dave
Sounds rich
Not as in comedic. But rich as in too much gas. Like this:
https://www.youtube.com/watch?v=R6dm9rN6oTs&NR=1
All the fuel is not being burnt in the chamber and is instead being burnt in the pipe. Where are you on jets and so forth? Is the intake completely opened up? To be confusing, are you getting enough air for the amount of gas you are flowing? Or are you getting too much gas for the amount of air you CAN flow? Is teh side panel opened up with the screens like the Team Honda bikes? This is a MUST DO.
This is a pretty good primer on our BRP carbs:
http://www.amazon.com/Motorcycle-Carburetor-Tune-up-Keihin-Carburetors/dp/B000IZJQQ6/ref=sr_1_1?ie=UTF8&s=dvd&qid=1240675754&sr=1-1
Ahhhh
The universal language!
touser wrote:Thank's, I'll check it out and "STAY OFF THE BEANS"
dave
» Oils Aren't Oils
» I bought a new GPS! - UPDATE
» Buying Advice
» Running at last
» Bleeding Front Brake Advice
» Buying Advice
» Running at last
