IMS 26L install
IMS 26L install
Before
After
Vacuum pump
Fuel tap and quick disconnects
Aluminium tape to protect tank from exhaust heat. (Exhaust wrap on order.)
Ignition key installation still fits
Indicator brackets contact tank on full lock
Spacers provided are too wide to fit so large nuts installed temporarily till I can turn down the spacers at work. (Tanker Brace on order)
So all in all I'm very impressed with the quality and fit of the tank with the two minor exeptions regarding the seat and spacers...I would say the quick disconnects are a must else you can not take the tank off with fuel in it.
After
Vacuum pump
Choke lever access possible but no way to get to idle adjustment while on the bike and barely when you are off the bike.
Slight bend in bracket fixes that. The plastic indicator housing just touches but the rubber mounting flexes so no issue.
Can’t get front seat mount to slide into place – anyone else had this issue? Might just velco for now to help keep in place but no huge deal.
Re: IMS 26L install
where did you get this and how much was it? I've been looking at the acerbis tank but haven't gotten around to buying one yet, but if this is truly 26L that's 6.86 gallons (a full gallon more than the acerbis) and thus more attractive, haha. Give us a nice review on it. Also, are you using the gas tank slosh stuff? I can't remember what it's called, but the foam stuff you put in the tank to help prevent the gas from sloshing around. I like the idea of a massive tank because I can fill it up all the way if I need it, or just fill it up with 3 gallons (if that foam stuff works well) and have less weight on the front forks. Let me know what you think of it, thanks.
-Rob
-Rob
Re: IMS 26L install
Got same tank, and if you bend the seat (stock-std seat) it'll slip into the pin on the tank.
That alu tape will come off though, know it.
Those quick connectors I hope have checkvalves in them? If not (in both halves) then you'll cause a fire when taking it off of a hot engine in the field - but it seems you know this already
Re: IMS 26L install
Hi Rob,RobbySkateboard wrote:where did you get this and how much was it? I've been looking at the acerbis tank but haven't gotten around to buying one yet, but if this is truly 26L that's 6.86 gallons (a full gallon more than the acerbis) and thus more attractive, haha. Give us a nice review on it. Also, are you using the gas tank slosh stuff? I can't remember what it's called, but the foam stuff you put in the tank to help prevent the gas from sloshing around. I like the idea of a massive tank because I can fill it up all the way if I need it, or just fill it up with 3 gallons (if that foam stuff works well) and have less weight on the front forks. Let me know what you think of it, thanks.
-Rob
I too was going for the Acerbis but then got enlightened as to the advantages of the IMS by a certain forum member. Anyway the more I saw the more I liked and bought it from atvgalaxy on ebay for $270 - good bit cheaper than the Acerbis I believe. The nice thing is the fuel pump that picks the fuel up from all the low spots and transfers it to the sump area where the fuel tap is.
I have only had a quick short ride so far but am riding to work tomorrow on it and then on saturday am heading to Jinja (where the source of the Nile is) for breakfast . Will report back about 'sloshing' later...but suspect I will get tank foam at some point.
Cheers
Re: IMS 26L install
Hey,BuRP wrote:Got same tank, and if you bend the seat (stock-std seat) it'll slip into the pin on the tank.
Just managed to get the seat on properly.....bit of bending and some slippery stuff around the pin and alot wiggling. Hopefully now its on it will take a 'set' in that position.
I have lots of tape at work.....had got exhaust wrap coming too.
Got the right check valves as well...although I busted one already...I had it sat in such a way that when the kick start returned it broke a bit of the plastic that holds the sliding metal plate in place and so the plate, spring and pin all popped out....good job I had ordered a spare .
Only concern is that starting will be a pain without access to the idle screw.....I usually tweak that up a turn or so to start from cold....do you have any problems Bart?
Overall I am really impressed with the tank.
Re: IMS 26L install
Yip, a fine tank it is.
I can reach my idle screw (TM40 mind) easily enough, and you're deadright in mentioning the 'upping' for a cold start being required, it makes life so much easier.
Can't remember the std carb anymore, have a good look and think of something maybe?
Edited: yeah, some wrap around the headers is a good idea, I had that too. Thorns will ravage it though, but then again it remains a dirtbike after all, it adds to the character
Re: IMS 26L install
well, rode it to work today 80% tarmac 20% dirt road and it felt fine. Started ok too just one extra kick to get her going - maybe the idle adjustment isn't so critical afterall........
longer ride tomorrow but not sure how much is dirt...
will report back
Cheers
will report back
Cheers
Re: IMS 26L install
Well, started fine again today, 2nd kick....
Filled it up to the top and this mornings ride was 240k's - so weird to do a complete ride on one tankful and have loads left over....Unfortunately the ride was basically all tarmac, because we had some street bikes with us, but there where plenty of speed bumps (or as we call them here ' speed mountains') that you launch off the top of and the bike handled fine. I tried out my giant loop coyote as well just for the fun of it and the bike handled fine. Both the tank and the coyote are awesome bits of kit.
The downside of the big tank though is that my butt doesn't get a rest as often now so my seat definitely needs some work...
iron butt
ha ha...!, yeah ive had to improve my seat as they're really a torture device in disquise, i widened mine just enough ,plus removed the foam first to bore 19mm holes half way thru, then reglued to the base, they are then like little shock absorbers, then i made a removable sheepskin padded cover for the long trasport sections, ive just fitted a 16l clark tank, about to find out how all me mods behave on a trip down our south island[ pics in the mods section]have fun
Tanker Brace
Well, got the tanker brace and installed it - only slight issue I had was getting a spanner (wrench? I'm multi-lingual ) on the engine mount bolt head as the rad that side is slightly tweaked - oh also I had to put a thinner washer on the engine mount bolt as there weren't enough threads to go through the nut. No big drama though. The brace is a great bit of kit, really well designed and manufactured - thanks Hodakaguy.
fuel consumption
having just completed 5700kms tour around sth isld of NZ, im glad to now be getting 15k's /l , abit perplexed as my mtrs very modded+ a fcr43.5mm carb, so with the 16L f/tank ive been getting 220k til reserve, with the std mtr/carb id struggle to get 100k from the whole tank[std 10l], reserve included
Re: IMS 26L install
That's not much on your standard tank, I got 140k's on the standard tank.
» XR680R What Jet fuel to install?
» Clarke 4.3 Gal. install
» BRP thermostat install help!!!
» Radiator Fan Install
