Fuel flow question
Fuel flow question
I've plumbed in my Acerbis 24L tank and I've got a question about the fuel flow to the carb. The inlet to the carb points straight up, so in order to prevent the fuel line from kinking and giving a low flow rate, the pipe goes up out of the carb and then gently curves around to join the two fuel lines from the petcocks.
The pipe from the carb goes up and bends around to come back down again, but the height of the bend is slightly higher than the petcock, by about an inch.
Is the fuel only gravity fed, so when the fuel level reaches the same height as the highest part of this curve the fuel flow will stop?? Or is there some scientific shenanigans like syphoning or vacuums occurring which means the carb will suck in the fuel even if this part of the fuel line is higher than the level of fuel in the tank?
I know the easy way to find out is ride it until it stops, but that then might involve pushing!
Re: Fuel flow question
unfortunately the Acerbis does hold fuel lower than your carb inlet - that is the reason that I got the IMS 26l tank. It has a vacuum driven pump that lifts the fuel from the lower spots and dumps it in a sump area where the fuel is fed to the carb.
Yes that is correct , the acerbiss tank has some fuel left in the bottom section and you cannot use it , thankfully its only a small amount so you can live with that .
» Fuel Tank
» Gas coming out of over flow tube
» how much fuel does brp use
» Fuel all over the floor
» Fuel Tap Rubber
» Fuel Tap Rubber
