Forks
Forks
I just changed the fork oil and noticed the one for is easier to push down that the other (for the first inch or two), I dont know if it was like this before is started.
I am pretty sure both have the same amount of oil and the comp and rebound are set the same on both
any ideas would be appreciated.
Re: Forks
Maybe it needs time to settle ?....let the oil get into all the littlw holes....if there are any lol
Re: Forks
Are you sure the oil level its the same ? you could have some air trapped in there .
Re: Forks
I did leave them for about 30 minutes before reinstalling the springs, but I will take them out and double check as there may be some air trapped
» replacement forks and top yoke
» CRF forks & yokes ?
» USD fork swap on XRR
» Front forks...what else is there
» wp 4860 sxs forks on xr
