replacement forks and top yoke
Post  fireblade reject on Sat Jun 09, 2012 9:44 pm
unfortunately I've had a little bump.
I've bent the left fork a little and cracked the top yoke (worse than cracked in fact).
I definitely need a new top triple clamp, so I'd like to hear any views on replacements available or am I better off looking for a salvaged set?
The forks still work fine as the bend is very high and doesn't affect the action. Is it possible to have it straightened? If not, the same as above really - like for like or an upgrade.
Frustrated
fireblade reject
http://www.transamtrail.co.uk
Re: replacement forks and top yoke
Post  Mauser on Sat Jun 09, 2012 11:27 pm
Ring Paul @ www.xr650r.co.uk he has a few sets of forks and bound to have a few yokes floating about.
Post  fireblade reject on Sun Jun 10, 2012 7:25 pm
once again. Thanks
fireblade reject
Post  BuRP on Sun Jun 10, 2012 7:33 pm
CBRReject,
you're going to hate me - I bet your bottom triple is also bent!
If the top goes the bottom one goes with, not always but almost always...... sorry if the case, but you better take it out & check.
Post  fireblade reject on Mon Jun 11, 2012 11:01 pm
Hi.
Ha ha yeh, cheers for that. It is
banana
fireblade reject
