Gearbox noise
Gearbox noise
On the topic of engine noise, how noisy are peoples gearboxes?
Mines noticeable and the noise goes away when I am stationary and pull in the clutch. Cant really say if its noisy when moving as it may be masked by other sounds (exhaust etc)
Obviously this is also assuming the noise is from the gearbox.
Re: Gearbox noise
tbh I am not sure if its from the gearbox or clutch related.
All I know is the noisy goes away when I pull the clutch in. I did change the clutch plates, judder springs last week and checked what I could and everything looked fine.
I didn't change the clutch bushing though, which apparently can be an issue on the 00 - 01 ones (mines an RY so I think 2000).
The noise hasn't got any worse and haven't seen any other piggies so I don't know if its a "normal" noise and to be honest I have only noticed it recently but it may have always been there as I have only ridden her 6 or 7 times so have only started to notice the "bad" points/habits of this new relationship.
Re: Gearbox noise
found this
WEAK CLUTCH BASKET DAMPENER SPRINGS
(at rear of clutch basket) - If these have sagged or lost tension the clutch will be noisy at idle and low revs, the noise will usually diminish when you pull in the clutch.
so may be nothing serious...
Re: Gearbox noise
Here's my baby with clutch in and out.... sorry about the dirty engine
https://www.youtube.com/watch?v=0dcpTczsMeU
Re: Gearbox noise
appleseed wrote:tbh I am not sure if its from the gearbox or clutch related.
I was paranoid about the sounds comming out of my engine untill i have heard new one , it sounded exactly the same ( like a bag of spanners / or a ducati if you like )
Re: Gearbox noise
Mauser wrote:Here's my baby with clutch in and out.... sorry about the dirty engine
Yupp , sounds like mine .
Re: Gearbox noise
does seem to sound different with the clutch disengaged but similar to mine. maybe quieter than mine.
I''ll try record mine tomorrow, but from the clutch side.
also the motor is farking filthy, you should ashamed !
Re: Gearbox noise
Mad Frosty wrote:Mauser wrote:Here's my baby with clutch in and out.... sorry about the dirty engine
Yeah yeah yours only sounds as quiet as mine as your gearbox is stuffed with sawdust.....
Re: Gearbox noise
Mauser wrote:Mad Frosty wrote:Mauser wrote:Here's my baby with clutch in and out.... sorry about the dirty engine
Its called the " magick dust " in the trade
Re: Gearbox noise
https://www.youtube.com/watch?v=6ePc6ZVJDh4&feature=youtu.be
the numberplate its rattling , this reminded me that i need to sort it out
Re: Gearbox noise
Nice bikes Gents, and Maddy's may be turned down in revs a bit I think - more engine braking then too
Re: Gearbox noise
Why are the rev's also hanging Fruitiness ?...when you blip my throttle she drops down straight away...maybe remove all the rear subframe and rear light assembly will help ?.....she looks clean but I still prefer my basic simple looking US spec baby.
» XR650r Gearbox mod.
» Another problem, too little oil in gearbox ... after rebuilt
» GEARBOX---gear fork issue help!
» engine noise normal or not
» Yes, another noise question from a newbie...
